Caliper sticking, Pads hanging up on 1 front |
jim_hoyland |
Oct 31 2004, 11:25 AM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Yesterday, my front left modified BMW 320i caliper began squeeking when pedal is off and going slow. Hit the pedal a couple of times and it went away. Got home and checked to see if caliper was hot. Pretty hot.
Is there a quick fix to this; or does the caliper need to be removed and sent in ? |
Rusty |
Oct 31 2004, 07:22 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Nope. No lubrication.
Rust in the cylinder bore usually causes the cylinders to stick. You can usually polish it out with some 400+ grit sandpaper when you do the rebuild. If you can R&R a caliper, you CAN rebuild the caliper. (IMG:style_emoticons/default/smile.gif) Recommend you do both both calipers on the same axle. Invest in a couple cans of brake cleaner to help clean things up. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 05:55 AM |
