| jimkelly |
Jul 13 2017, 09:58 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
http://www.autoatlanta.com/Porsche-914-Mot...ounts-srch.html
is there a difference in height or thickness from the 911 mount vs the 914 mount of this style? thanks (IMG:style_emoticons/default/smile.gif) Attached image(s)
| jimkelly |
Jul 14 2017, 11:48 AM
it's always something (IMG:style_emoticons/default/smile.gif)
so it looks like 2ea of this washer for each mount is best, pn: 90130531100 are they big enough to hold engine off the floor if rubber mounts fails? seems like all these metal washers, regardless of style, the mounts loses most of its flexibility (IMG:style_emoticons/default/idea.gif) jim Attached image(s)
| BillC |
Jul 14 2017, 12:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 701 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
it's always something (IMG:style_emoticons/default/smile.gif) so it looks like 2ea of this washer is best, pn: 90130531100 are they big enough to hold engine off the floor if rubber mounts fails? seems like all these metal washers, regardless of style, the mounts loses most of its flexibility (IMG:style_emoticons/default/idea.gif) jim Yes, those washers will work. However, you'll four of them, one above and one under each mount. The mounts are designed to work with those washers. The mounts actually aren't supposed to have a lot of flexibility. Their primary purpose is to isolate vibration, without letting the engine/trans "float" around too much. |
jimkelly motor mount difference between 911 and 914 style Jul 13 2017, 09:58 AM
gms I put them on my 914/6 as trans mounts as I recall... Jul 13 2017, 11:02 AM
stownsen914 I believe the 914 mounts are substantially softer,... Jul 13 2017, 11:50 AM
SirAndy The 911 sport mounts are the same thickness but yo... Jul 13 2017, 11:54 AM
jimkelly because on the later cars the side shift engine ba... Jul 13 2017, 03:09 PM
Steve I think the rear 914-4 ones had holes through the ... Jul 13 2017, 03:42 PM
flmont I was actually going to ask if the 911 mount's... Jul 13 2017, 06:18 PM
Dave_Darling
I was actually going to ask if the 911 mount... Jul 14 2017, 09:30 AM
jimkelly i plan to use 911 mount and these 2 oem 914 washer... Jul 13 2017, 07:21 PM
flmont Ahh Ok Ill look in to that ...Thanks Jul 13 2017, 07:46 PM
GeorgeRud The 911 mount will work as described. The origina... Jul 13 2017, 08:19 PM
gms I just saw the mounts for sale on Pelican .
You w... Jul 14 2017, 09:41 AM
gms 901-305-311-00
they look like this
Jul 14 2017, 09:53 AM
Andyrew 911 sport mounts for the trani (What you have pict... Jul 14 2017, 10:37 AM
gms
are they big enough to hold engine off the floor ... Jul 14 2017, 12:26 PM
mepstein I wouldn't buy used. The new ones aren't t... Jul 14 2017, 12:34 PM
jimkelly thanks guys :wavebye:
yup, seems best to buy mo... Jul 14 2017, 12:40 PM
11tenths Then there's these...
[url=https://w... Jul 14 2017, 05:17 PM
[url=https://... Jul 15 2017, 11:09 AM
jimkelly probably :rotfl: Jul 15 2017, 05:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:50 PM |
