FS SSS Super Shiny Stuff |
bdstone914 |
May 29 2017, 09:19 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Steel Early type Gas Caps $30 Four available. New seals will be included.
Hold down plate and bolt for spare tire $30 Two or more sets. Near Perfect sets. Fuel Rails and injector hold down set of 6 parts $40. Two or more correct sets. Several more with both rails having pressure test ports. It is reported the a test port on the Passenger side can interfere with the MPS mounting. Controlled by size and shape of the elbows on the fuel injectors to fuel rails. Voltage regulator Covers. $15 each , 6 available. Replated clear zinc. There are some imperfections in plating where the wires were wrapped around them. Various markings on the tops. Pain in the butt to clean and polish. Attached thumbnail(s) |
MikeInMunich |
Jul 15 2017, 06:22 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Wow Bruce, nice work! (IMG:style_emoticons/default/blink.gif)
I've been thinking about your pedal clusters recently because my clutch pedal is squeaking when I depress it. Gunnex isn't getting in there good enough to stop it, although it doesn't squeak anymore if I press downward rapidly. I'm going to take it out and clean it up better than I can with it still installed. |
bdstone914 |
Jul 15 2017, 06:56 AM
Wow Bruce, nice work! (IMG:style_emoticons/default/blink.gif) I've been thinking about your pedal clusters recently because my clutch pedal is squeaking when I depress it. Gunnex isn't getting in there good enough to stop it, although it doesn't squeak anymore if I press downward rapidly. I'm going to take it out and clean it up better than I can with it still installed. Just pull the pedal board as removing it does not give any better access internally. Never used Gunnex but many lubes deteriorate the plastic bushings. Turns them into mush. I use bronze bushings and synthetic grease. Or i can build you one without out a core return and you swap it out. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:31 PM |
