| Optimusglen |
Jun 15 2017, 09:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 955 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest
15 months ago I bought a crusty old 1971 914-4 that had been sitting in a garage for 20 years getting peed and chewed on by all sorts of creatures.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1497540074.1.jpg) I started the project with a plan of it being driveable at the 1 year mark. Since then I've done an engine build, carb rebuild, brake rebuild with 5-lug swap, fuel system rebuild, interior rebuild, suspension rebuild, and some general freshening up. Oh, I forgot to mention that my wife and I had a baby too, safe to say it's been a pretty busy 15 months. Here's the build thread if anyone's interested. http://www.914world.com/bbs2/index.php?sho...=277349&hl= Anyway, the result is good. It's running and driving, the 1911 is strong and runs well. Handles great considering there are no sway bars. Tail shifter is as vague as you imagine though, and the engine is still sub 100hp so it's not incredibly fast. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1496565572.1.jpg) It's first real public appearance was at the June C&C that I attended with a good friend in his 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1497540075.2.jpg) Exiting a cloverleaf he pulled away like I was standing still. To add insult to injury a minivan pulled away too. This lit a little spark, I wanted more power. I started crunching numbers for building the type 4, goal is around 150hp. Can you get 150hp in a type 4 that's home built? Sure, lots of people have done it. But there's an even better, more expensive and headache inducing option... A friend of mine owns Flat Six in Minneapolis, MN. About 40 minutes from me. Sent him a message inquiring about core 6 cylinders and ended up coming home with this. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1497540075.3.jpg) It's a 2.2 from a 911T, the 125hp version. On top are a pair of Zenith carbs that will work fine for my purposes after a complete rebuild. It turns over smoothly and you can feel when it comes up on compression. Good signs for an otherwise unknown engine. If you had followed along in my build thread you'll know that I got some amazing deals, both for parts and for the car itself. The 6 does not disappoint in that regard, but I wont be sharing the details here. Perhaps the best part of the deal is that he said if I get into it and find that anything is FUBAR, I can get a no-charge replacement from him since he has Parted several 2.2's. Again, this is a friend, I don't expect him to do this for anyone. With his help we laid out a build plan. Going to get the T cams reground to the E profiles paired with higher compression pistons. Cylinders are iron so I can bore those. Goal is around 150ish hp. It'll be a "budget" build in the sense that I'm not going for huge power and will be doing the assembly/cleaning myself. I won't be cutting corners with machine work and inspection though. I will be mating it with a side-shift trans using the early 911 flywheel. flywheel and bulkhead weld-in mount already on order. It's not likely that I'll be doing a conventional 914-6 oil tank, it just seems like so much money for what you get. We will see though, as time progresses I may change my mind. This will be a driver, not trying to make it a show queen or original to a real 914-6. I want to keep the utility of both trunks but I want the mechanicals to be functionally excellent. Time frame is significantly longer than the original build. Planning at least a year or two considering the work and money involved. I'll update this thread moving forward and not my original build thread, kind of a new chapter if you will. Fortunately the 914 is perfectly driveable while I collect and rebuild. (IMG:style_emoticons/default/smile.gif) So here's to the next chapeter, however expensive and time consuming it may be. (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-19709-1497540075.4.gif) |
| Optimusglen |
Jul 15 2017, 07:49 PM
Case split, nothing scary!
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500169771.1.jpg) |
Optimusglen Welcome to the slippery slope... Jun 15 2017, 09:21 AM
Tom_T Quite a change! :trophy:
Enjoy! :driving... Jun 15 2017, 09:30 AM
Alphaogre http://www.914world.com/bbs2/uploads_offsite/i.img... Jun 15 2017, 09:47 AM
Steve It's only money and time and lots of it, but w... Jun 15 2017, 10:10 AM
mb911 I can provide you a 6 tank kit for $350 if yo... Jun 15 2017, 10:24 AM
forrestkhaag Your plan is solid /drive while collecting parts i... Jun 15 2017, 10:35 AM
Mueller Great looking car, doing a "stockish" Ty... Jun 15 2017, 12:12 PM
mb911 I suppose i should add that i always have second o... Jun 15 2017, 02:11 PM
Optimusglen
I suppose i should add that i always have second ... Jun 15 2017, 02:33 PM
porschetub
I suppose i should add that i always have second... Jun 15 2017, 04:24 PM
mb911
I suppose i should add that i always have second... Jun 15 2017, 08:05 PM
porschetub
I suppose i should add that i always have second... Jun 15 2017, 10:47 PM
mepstein The stock 914-6 tank is a really nice way to handl... Jun 15 2017, 04:52 PM
Krieger Your sick, very sick! Good luck with the buil... Jun 15 2017, 09:25 PM
Nie Zu Alt Good luck with the build! I'll be followin... Jun 15 2017, 09:43 PM
Larmo63 Many of us are doing /6 conversions right now. We ... Jun 15 2017, 10:52 PM
Optimusglen Started the teardown and did some much needed gara... Jun 17 2017, 01:54 PM
porschetub
Started the teardown and did some much needed gar... Jun 17 2017, 08:19 PM
mb911
[quote name='Optimusglen' post='2497598' date='Ju... Jun 18 2017, 07:22 AM
[quote name='porschetub' post='2497711' date='Jun... Jun 19 2017, 10:05 AM
mb911 At least your car is 1 piece. My engine is still a... Jun 17 2017, 03:48 PM
pete-stevers You will not regret this conversion... However a n... Jun 17 2017, 09:33 PM
colingreene So your friends with Chris, His 911 looks so good ... Jun 19 2017, 09:37 AM
Optimusglen
So your friends with Chris, His 911 looks so good... Jun 22 2017, 11:23 AM
Optimusglen Started a little bit of the tear down. Head studs ... Jun 22 2017, 09:24 AM
mb911
Started a little bit of the tear down. Head studs... Jun 22 2017, 09:32 AM
Optimusglen After talking with someone who's been building... Jul 6 2017, 01:50 PM
mb911 Yup I am actually using mechanical adjusters and r... Jul 6 2017, 02:43 PM
iwanta914-6 You are nuts! LOL
You had this car on the roa... Jul 6 2017, 03:20 PM
Optimusglen
You are nuts! LOL
You had this car on the ro... Jul 6 2017, 06:55 PM
Mark Henry There is a way to make the Carrera tensioners no f... Jul 6 2017, 04:26 PM
Mark Henry I'd seriously take Ben up on his offer, the pr... Jul 6 2017, 04:31 PM
Optimusglen
I'd seriously take Ben up on his offer, the p... Jul 6 2017, 07:09 PM
Larmo63 I doubt if I will do Carrera tensioners.
Slipper... Jul 6 2017, 09:10 PM
mb911
Slippe... Jul 7 2017, 08:53 AM
burton73
Slipp... Jul 14 2017, 01:16 PM
rgalla9146
[quote name='mb911' post='2503823' date='Jul 7 20... Feb 27 2018, 04:21 PM
GeorgeRud I'd at least recommend using some tensioner co... Jul 6 2017, 09:22 PM
Optimusglen
I'd at least recommend using some tensioner c... Jul 7 2017, 07:49 AM
Mark Henry
I'd at least recommend using some tensioner c... Jul 7 2017, 08:28 AM
Mark Henry BTW and just an FYI Ben would have given you a bet... Jul 7 2017, 08:34 AM
mb911
BTW and just an FYI Ben would have given you a be... Jul 7 2017, 08:52 AM
Optimusglen
BTW and just an FYI Ben would have given you a be... Jul 7 2017, 08:55 AM
Mark Henry
... proper case savers installed (I will probably... Jul 7 2017, 09:28 AM
Optimusglen
Case savers have to be done on a mill, I've ... Jul 7 2017, 09:33 AM
mb911 So one option for tensioners when talking extensiv... Jul 7 2017, 09:01 AM
Mark Henry That's great...but I bet you still go over bud... Jul 7 2017, 09:58 AM
Optimusglen
That's great...but I bet you still go over bu... Jul 7 2017, 10:08 AM
Mark Henry
That's great...but I bet you still go over b... Jul 7 2017, 11:25 AM
mb911
[quote name='Optimusglen' post='2503842' date='Ju... Jul 7 2017, 02:43 PM
jcambo7 :popcorn:
I have a 70's 911T in my 914. If y... Jul 7 2017, 05:25 PM
Optimusglen Yesterday I made the drive to a friends to pick up... Jul 13 2017, 09:30 AM
Optimusglen Tore down a bit more. #4/5/6 pistons, cylinders, a... Jul 14 2017, 08:37 AM
Justinp71 :Qarl:
Hard too beat the sound and feel of the ... Jul 14 2017, 10:10 AM
mb911 :agree: I get all my parts from Henry and he just... Jul 14 2017, 10:37 AM
mb911 Did you find any chunk s in the sump screen? Jul 14 2017, 10:38 AM
Optimusglen screen is clear of any/all chunks.
Yeah I have ti... Jul 14 2017, 10:44 AM
bigkensteele
Yeah I have t... Jul 14 2017, 12:51 PM
Optimusglen
What would be considered high compression? I hav... Jul 14 2017, 02:22 PM
mb911
Yeah I have t... Jul 14 2017, 04:23 PM
Larmo63 I would be quite happy with what you found on the ... Jul 14 2017, 07:51 PM
JmuRiz Looks lucky thus far. My previously rebuilt 2.7 co... Jul 15 2017, 07:37 AM
bretth
Nothing scary bu... Jul 15 2017, 10:55 PM
Optimusglen
Nothing scary b... Jul 16 2017, 05:33 AM
mb911
Nothing scary b... Jul 16 2017, 08:17 AM
Nothing scary b... Jul 18 2017, 01:32 PM
bretth
[quote name='bretth' post='2506818' date='Jul 16 ... Jul 18 2017, 01:44 PM
GeorgeRud I took the easy way and had Henry rebuild my 2.7, ... Jul 16 2017, 08:59 AM
mb911
I took the easy way and had Henry rebuild my 2.7,... Jul 16 2017, 10:40 AM
Optimusglen Initial inspection and measurement taking tonight.... Jul 18 2017, 01:14 PM
Optimusglen Good news! Crank journals are all perfectly in... Jul 18 2017, 08:38 PM
mb911 Good news is that rebuilt rods are fairly inexpens... Jul 19 2017, 02:52 PM
Optimusglen Ok, been a long time without an update.
Picked up... Aug 22 2017, 09:09 AM
iamchappy I'd love to stop in while your slapping it tog... Aug 22 2017, 03:07 PM
Optimusglen
I'd love to stop in while your slapping it to... Aug 22 2017, 03:27 PM
iamchappy I'm pretty good but not great at body work, an... Aug 22 2017, 06:36 PM
porschetub Running stockish 2.2 T headers and upgraded igniti... Aug 23 2017, 01:36 AM
Optimusglen I've been collecting parts, i.e. all the beari... Sep 11 2017, 09:01 AM
Optimusglen Update time, been holding off on moving too far fo... Nov 6 2017, 08:33 AM
Optimusglen Been awhile since I've posted any project news... Feb 27 2018, 08:26 AM
mb911
Been awhile since I've posted any project new... Feb 27 2018, 09:03 AM
Optimusglen In your experience was it 1.625 I.D. or O.D. ?
W... Feb 27 2018, 10:25 AM
mb911
... Feb 27 2018, 11:48 AM
Optimusglen Thanks for the feedback, I have some messages out ... Feb 27 2018, 11:54 AM
mb911
Thanks for the feedback, I have some messages out... Feb 27 2018, 12:11 PM
Optimusglen Looks like I'll be holding onto these until th... Feb 27 2018, 12:37 PM
Optimusglen Update: Today I went out and did a test assembly o... Apr 5 2018, 12:00 PM
BK911 2.4 crank and rods. Apr 5 2018, 01:06 PM
mb911 I am sorry to hear that.. :( Apr 5 2018, 04:05 PM
Optimusglen
It's ok, it... Apr 6 2018, 08:03 AM
gereed75 My experience is that main bearing bores ovalize a... Apr 6 2018, 09:56 AM
Optimusglen Thought I should update the thread.
I got my head... Apr 25 2018, 08:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 03:24 AM |
