tazz9924 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None ![]() |
Ok so, i had a click from the front end of my car, i expected it to be the balljoints because their trash. come to find out the thing u screw in to retain the shock came off ( i did tighten the shift out of it before i installed it) and my newer koni shock has a hole rubbed in it and leaked all of its fluid. meanwhile the real killer is i cant rescrew the retainer back in because the threads on the tube thing are rubbed flat. My question is do i try to get the biggest tap ive ever seen or do i have to buy a whole new knuckle:( ?
The real killer is im moving to sacramento in two weeks and im driving the 914 down there! help! pm me if u got a drive side 911s koni strut/ knuckle thing ur willing to sell ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Cutting it shorter is not an option. The strut insert goes all the way to the bottom. The strut would stick out the top.
Last single Koni I have like that sold for $350. Koni and Boge strut tops take the same thread. I would graft on a Boge top to the Koni. You can use a 914 strut. I have a bunch. For $20 I will cut off the top and mail it. Get a good welder to weld on the top section. Bruce |
tazz9924 |
Cutting it shorter is not an option. The strut insert goes all the way to the bottom. The strut would stick out the top. Last single Koni I have like that sold for $350. Koni and Boge strut tops take the same thread. I would graft on a Boge top to the Koni. You can use a 914 strut. I have a bunch. For $20 I will cut off the top and mail it. Get a good welder to weld on the top section. Bruce i have a 914 strut but it wasn't the same size |
Lo-Fi Version | Time is now: 17th June 2024 - 02:57 AM |
