911 Front suspension is goofed help!, threads stripped on strut cartridge retainer |
tazz9924 |
Jul 16 2017, 05:03 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Ok so, i had a click from the front end of my car, i expected it to be the balljoints because their trash. come to find out the thing u screw in to retain the shock came off ( i did tighten the shift out of it before i installed it) and my newer koni shock has a hole rubbed in it and leaked all of its fluid. meanwhile the real killer is i cant rescrew the retainer back in because the threads on the tube thing are rubbed flat. My question is do i try to get the biggest tap ive ever seen or do i have to buy a whole new knuckle:( ?
The real killer is im moving to sacramento in two weeks and im driving the 914 down there! help! pm me if u got a drive side 911s koni strut/ knuckle thing ur willing to sell |
Cracker |
Jul 16 2017, 08:46 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
This may not be an option or good idea for you but...I have a GREAT machine shop that can fix most anything. Do you have access to one in your area? A good shop could make a new retaining nut modified to accommodate the repair. The strut tube could be cut lower (shortened) if necessary if the threads couldn't be straightened near the top. Again, maybe not a real solution but it got me thinking.
T |
tazz9924 |
Jul 17 2017, 05:56 PM
This may not be an option or good idea for you but...I have a GREAT machine shop that can fix most anything. Do you have access to one in your area? A good shop could make a new retaining nut modified to accommodate the repair. The strut tube could be cut lower (shortened) if necessary if the threads couldn't be straightened near the top. Again, maybe not a real solution but it got me thinking. T Took it to my machinest today, he said he can and will do it, he's cutting off the top and welding on a new bit with new threads! Weight taken off my shoulders! |
Lo-Fi Version | Time is now: 17th June 2024 - 03:59 AM |
