> 914 stock stub axle - dimension?
jimkelly
post Jul 17 2017, 11:38 AM
Delaware USA
anyone have a 914 stub axle laying around?
i was wondering what the OD is of the splined area.
i'm thinking of using a second stub axle bolted to main stub axle and having the second splined to fit this vw splined flange that is type1 to type2/4 (924/944 100mm cv), for wheel side.
or simply turn down the stub axle so the flange can simply be welded to it. this would make the trans side and wheel side easy, but simply needing welding, after cutting and lathing.
pair of 924 axles $150 DTA brand on ebay.
4 flanges $35 x 4ea = $140
924 axles are 16.125" AND 944 AXLES ARE ?"
http://www.blindchickenracing.com/how_to/c...s/axles_101.htm
jimkelly
post Jul 17 2017, 02:59 PM
Delaware USA
my thought is that with everyone saying that when cutting and resplining a stock 914 axle to use with a suby cv at trans and 914 cv at wheel, that there is practically no margin for error on length, that two flanges and a 924 or 944 axle assy has got to be more forgiving, and stronger too.
are you bolting the two stub axles together or welding them together? is your flange attached using the splines or is your flange going to be welded to the innermost stub axle?
i am leaning towards welding it all together.
Phoenix-MN
post Jul 18 2017, 06:59 AM
QUOTE(jimkelly @ Jul 17 2017, 12:59 PM) *
my plan is to bolt them together using the two 10mm roll pins, the flange will be attached using the splines with a washer and snap ring. I'll be cutting the threaded end of the stub axle off.
- Lo-Fi Version Time is now: 25th September 2026 - 03:45 PM
