Speedo, and an Odd |
kkid |
Jun 21 2017, 09:22 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Hey guys,
So my Creamsicle has finally seen a road after about 1.5 year of jack stands time. (IMG:style_emoticons/default/cheer.gif) Now the speedo didn't work so I changed the cable. I see other cars passing by like a rocket while going at 65pmh so the speedo needle is way off??? I will check this with a GPS today. Anyways, the odometer is not working at all. This is a bigger problem. (IMG:style_emoticons/default/sad.gif) Has anyone encountered the same and succeeded to repair??? The speedo works(barely) but odo does not. Let me know. Thanks, kkid (IMG:style_emoticons/default/smile.gif) |
kkid |
Jul 23 2017, 03:23 PM
So I pinched/squeezed the hub of the pot-metal gear from both side then put it back to where it was. With some drag while skewering the shaft to the pot metal gear along with all the other gears, I hoped it would not come off again (at least for a while). I didn't fully understand about making "all gears the right positions" but I assumed I did not move anything since I got all the gears wrapped up with a blue masking tape prior to the shaft removal. So I put everything back together as is and tested on the car.
And it works great!!! It's (IMG:style_emoticons/default/beer.gif) time. Wish I can (IMG:style_emoticons/default/beerchug.gif) with you timothy. Thanks a lot for the help!!! kkid (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:31 PM |
