| steuspeed |
Jul 22 2017, 05:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Installed a new Ate 17mm Master and rebuilt the right rear caliper. It was sticking on. I have gone around several times bleeding each corner with the pedal method. It still does not feel 100% solid. Any suggestions out there? Maybe air trapped by the top bleeders? I'm using Ate super blue which I found is no longer available (IMG:style_emoticons/default/hissyfit.gif) I did not bench bleed the master.
| McMark |
Jul 24 2017, 05:13 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
First, make sure the plunger on the brake pedal is adjusted. There should be a small amount of pedal movement before the plunger actually contacts the piston in the MC. If the piston can't fully retract, that's an issue.
Make 3 plugs (How To here). Depress the brake pedal (with a tool, a brick, or a helper), this will keep reservoir fluid from continually dripping out and making a mess by blocking the internal MC passages. Do this ANY time you're cracking into the fluid system. Remove the three brake lines from the MC and install plugs (yes, fully plugged off). Get in the car and press the pedal until it's rock hard (not a little hard, fully, no-motion, rock hard). No cracking lines or opening bleeders. Switch back and forth from fully pressing the pedal to tapping the pedal with your foot, without depressing it, and the back and forth between those two. The tapping works really well for the MC bleed as it knocks more bubbles loose, AND the plugs mean the air has nowhere to go, so fully pressing the pedal closes the MC internal passages, so air can only bubble up into the reservoir when the pedal is 90% up or more. Now your MC is fully bled. (IMG:style_emoticons/default/smilie_pokal.gif) Now one at a time bring the brake calipers back in. Remove the rearward plug and reinstall the line. Bleed both rear calipers until the pedal is hard (make sure the venting clearance is set). Now your MC and rear brakes are bled. (IMG:style_emoticons/default/smilie_pokal.gif) Remove one of the other two plugs and reinstall the line. Bleed the caliper that you just added until the pedal is hard. Remove the last plug and reinstall the line. Bleed the final caliper until the pedal is hard. Now your entire brake system is bled. (IMG:style_emoticons/default/monkeydance.gif) If you don't fully bleed the MC you will either spent TONS of time chasing bubbles, or give up and just accept sub-par brakes. Follow that system and you'll get the firmest pedal in the shortest amount of time. If the pedal feels SAFE take a short test drive. Bleed the brakes at all four calipers again, just to release any bubbles that collected in the caliper. Repeat the drive and bleed process a few more times with longer drives in between bleedings. Again, make sure the pedal feels SAFE!!!! |
steuspeed Brake bleeding help Jul 22 2017, 05:23 PM
76-914 You might be pissing up a rope until you get that ... Jul 23 2017, 07:58 AM
steuspeed
You might be pissing up a rope until you get that... Jul 23 2017, 07:53 PM
banananose914
You might be pissing up a rope until you get that... Jul 23 2017, 09:15 PM
porschetub
You might be pissing up a rope until you get that... Jul 23 2017, 09:54 PM
steuspeed
You might be pissing up a rope until you get tha... Jul 24 2017, 02:14 AM
michael7810 You can bleed the MC by cracking the lines one at ... Jul 23 2017, 08:06 AM
steuspeed
You can bleed the MC by cracking the lines one at... Jul 23 2017, 07:52 PM
mlindner And then there's the pressure regulator, air m... Jul 23 2017, 08:47 AM
GeorgeRud I had good luck by pressure bleeding the brakes, t... Jul 23 2017, 07:59 PM
jsaum Are you getting any pedal or is it going all the w... Jul 23 2017, 08:02 PM
steuspeed
Are you getting any pedal or is it going all the ... Jul 23 2017, 08:48 PM
Perry Kiehl Here you go Stu
Here's how I bleed a 914 brake... Jul 23 2017, 08:27 PM
steuspeed
Here you go Stu
Here's how I bleed a 914 brak... Jul 23 2017, 08:54 PM
Dave_Darling Maybe air trapped by the top bleeders?
Are you n... Jul 23 2017, 09:29 PM
steuspeed
Are you ... Jul 23 2017, 09:35 PM
Racer Yes, ATE blue is no longer available.. only Gold. ... Jul 24 2017, 09:32 AM
mepstein If you don't have an impact wrench for removin... Jul 24 2017, 09:54 AM
steuspeed So my buddy brought over his Modine pressure brake... Aug 14 2017, 11:48 PM
McMark You ended up doing it in an usual way, but you bas... Aug 15 2017, 01:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th June 2026 - 01:21 AM |
