Bilstein strut insert, Fitment issue |
Aualexa1 |
Jul 24 2017, 05:33 PM
Newbie Group: Members Posts: 45 Joined: 17-June 17 From: South Jersey Member No.: 21,189 Region Association: MidAtlantic Region |
I ordered new Bilstein strut inserts (part number 34-001127-M512) to replace the old Koni's (part number 82R-1730) that I removed from my '73 914. Both inserts should fit a Boge strut, but the new Bilsteins are too tall (about 3 mm longer than the Koni's) and don't fit the strut housing. Any idea what's wrong? Did I order the wrong part?
Attached thumbnail(s) |
914Sixer |
Jul 24 2017, 07:40 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Does this happen on both sides or just one? You may have a bent housing if it only does it on one.
Aualexa1 |
Jul 24 2017, 07:43 PM
Does this happen on both sides or just one? You may have a bent housing if it only does it on one. I checked and it is both sides with both housings and both inserts. When I look in the bottom hole where the ball joint would enter, it looks like the bottom of the strut insert is all the way down and bottomed out. |
Lo-Fi Version | Time is now: 6th June 2024 - 11:34 PM |
