Sail panel vinyl |
Sail panel vinyl |
J123young |
Jul 24 2017, 08:03 PM
Member Group: Members Posts: 50 Joined: 1-February 17 From: Fenton, MO. Member No.: 20,801 Region Association: None |
My 914 has painted sail panels and I would like to install the vinyl. Need some advice on where to purchase. I found it on a few websites but don't want some cheap stuff. Also anyone recommend a adhesive?
Garland |
Jul 25 2017, 07:34 PM
Restoration Fanatic Group: Members Posts: 1,330 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
There's a technique called registering. Once you have it positioned where you want it, and before applying any glue tape one side in five or more spots, like hinges on a door. Once you're happy with the location and the hinges, apply the glue start at the center hinge and Roll on the material while smoothing to both sides as you go.
Porschef |
Jul 25 2017, 07:40 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
There's a technique called registering. Once you have it positioned where you want it, and before applying any glue tape one side in five or more spots, like hinges on a door. Once you're happy with the location and the hinges, apply the glue start at the center hinge and Roll on the material while smoothing to both sides as you go. Best way to do it. I used 3M 90 also, follow instructions and you should be fine. Good luck with it. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:50 AM |
