Help me find the time bomb....., Rocker arm shaft fell out....found two nuts and one wavy washer |
second wind |
Jul 26 2017, 12:50 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Here is a stresser.....my '73 2.0 lost power and during diagnosis found out rocker arm shaft had come loose and fallen out. No damage to anything except a groove worn into the pushrod two inches in from the valve cover side. I found the two nuts but only one wavy washer. Car runs with no noises or any odd sounds but I hate to button it up without finding the missing washer. Changed oil and nothing on super magnet plug. Any ideas where it might be?? Thank you!!
gg |
Valy |
Jul 26 2017, 01:35 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
1. I would assume the cut in the pushrod is from the retaining wire that either released and moved when the rockers shaft released or was incorrectly mounted to begin with.
2. It might be that the shaft released because you were missing that wavy washer, that's there to prevent the nut to untie under vibration. 3. The only place that washer can go is in the pushrods tubes. There's no way for it to reach the combustion chamber without a big hole in the head. Also it can't pass to the crank side. |
second wind |
Jul 27 2017, 03:53 PM
1. I would assume the cut in the pushrod is from the retaining wire that either released and moved when the rockers shaft released or was incorrectly mounted to begin with. 2. It might be that the shaft released because you were missing that wavy washer, that's there to prevent the nut to untie under vibration. 3. The only place that washer can go is in the pushrods tubes. There's no way for it to reach the combustion chamber without a big hole in the head. Also it can't pass to the crank side. Hello Valy...your post gave me hope that the washer, if it exists, is closeby and can't destroy my engine. What the heck is the retaining wire anyway? Seems like the culprit to me. Can I just cut it out? Thank you, gg |
Lo-Fi Version | Time is now: 9th June 2024 - 08:12 PM |
