Help me find the time bomb....., Rocker arm shaft fell out....found two nuts and one wavy washer |
second wind |
Jul 26 2017, 12:50 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Here is a stresser.....my '73 2.0 lost power and during diagnosis found out rocker arm shaft had come loose and fallen out. No damage to anything except a groove worn into the pushrod two inches in from the valve cover side. I found the two nuts but only one wavy washer. Car runs with no noises or any odd sounds but I hate to button it up without finding the missing washer. Changed oil and nothing on super magnet plug. Any ideas where it might be?? Thank you!!
gg |
Valy |
Jul 27 2017, 08:42 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
BTW, the magnet trick might not work since the tubes are metal and the lifters are metal as well as the washer. The magnet will stick to anything in there and the washer may also get stuck at the end of the pushrod. You have to take all 4 tubes out and check inside and on the lifters as well. If you can show a picture of ALL 4 pushrod, including edges, we might see a clue of where the washer hides.
But, as I initially said, it might be that there was no washer and that's why the nut came off. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:40 PM |
