Engine mount brackets |
JFG |
Jul 30 2017, 04:18 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Can someone tell me the dimensions of the brackets. It would appear I have been sold the wrong ones.
I can cut these and weld them but I don't know how high or low the rubber mount should be. Ideally I need to know the distance between the middle of the top bolt hole down to the top of the small shelf that the rubber bolts onto. |
bdstone914 |
Jul 30 2017, 08:19 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Good luck finding used ones. I posted a WTB ad with no replies. The other difference is the square mounting hole location. I could not find a bus mount for comparison. I think you can swap the shelf part side to side and bend and reweld them. Or drill a rounds hole. The square hole matches the square on the top of the mount to keep it from turning. If the engine and bar are out of the car I would jig up the brackets to the engine and use the holes in the bar to get the C-C distance correct for the mount holes and get the shelf parts horizontal.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 02:30 PM |
