Clutch pedal to the floor, Pushed clutch in and pedal went to the floor |
tsvo |
Jul 30 2017, 01:26 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
Hello, i have an issue with my clutch pedal. I was driving and pushed the clutch in to shift. I heard a nreaking noise and yhe pedal went to the floor. The peadal stil has tension when you move it with your hand, however it goes straight back to rhe floor. I will try to add a couple pictures. Any suggestions?
Attached thumbnail(s) |
bdstone914 |
Jul 30 2017, 02:42 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Broken cabel? look at the cabl at the trans and see if it has slack. the clutch clevis can also wear thru the shaft arm ar the pedal set. look at it in the tunnel.
Lo-Fi Version | Time is now: 9th June 2024 - 08:57 PM |
