worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,488 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
We run silicone brake fluid in our LBCs (Little British Cars) and this is widely accepted among that crowd. This week I am putting new front wheel cylinders in the 47 Dodge P.U. truck cause we don't run it enough and they pitted.
So why not use the silicone fluid in a 914? Yes, there is a slight compression you can feel in the pedal, but in my TR6 you can hardly feel it. I now have enough toys so that routine maintenance is a pretty big chore. Keeping up with batteries and tires is bad enough. Yes, I know that you should bleed out the old fluid, but frankly I doubt that would have helped me with the truck. The problem was the lack of movement of the seals over the cylinder. My time flies! So - what do you think? Thanks, Warren |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,504 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
DOT 4 is fine for any applications, even racing. And in my experience DOT 5 creates a funky pedal, and that was after running multiple cans through the system. And it costs more.
There's just no value in DOT 5. I run ATE Blue (while I still have some) and Amber/Gold in everything, street and race. |
worn |
DOT 4 is fine for any applications, even racing. And in my experience DOT 5 creates a funky pedal, and that was after running multiple cans through the system. And it costs more. There's just no value in DOT 5. I run ATE Blue (while I still have some) and Amber/Gold in everything, street and race. The value that the British crowd sees is reduced damage due to humidity in the fluid, a process that starts the moment you open the bottle. I agree that it isn't suitable for racing. With six toy cars I found I couldn't do big restoration and conversion and keep track of bleeding the brakes on time. Also, I am old with a bad back. Unfortunately that 47 Dodge truck is in truth hard to drive, so it sort of languished. That thing is so hard to steer and stop I wouldn't consider experimenting with silicone. On the other hand my TR6 with silicone stops quite a bit better than my 914 with DOT 4 - but then the TR has a vacuum booster. I am not trying to talk anyone into this, but I am a scientist, so I want the reasons people have, including subjective ones, and in Wisconsin we are required to Sift and Winnow the ideas. Sometimes. Thanks to all who responded. |
Lo-Fi Version | Time is now: 1st July 2025 - 04:09 AM |
