worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,488 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
We run silicone brake fluid in our LBCs (Little British Cars) and this is widely accepted among that crowd. This week I am putting new front wheel cylinders in the 47 Dodge P.U. truck cause we don't run it enough and they pitted.
So why not use the silicone fluid in a 914? Yes, there is a slight compression you can feel in the pedal, but in my TR6 you can hardly feel it. I now have enough toys so that routine maintenance is a pretty big chore. Keeping up with batteries and tires is bad enough. Yes, I know that you should bleed out the old fluid, but frankly I doubt that would have helped me with the truck. The problem was the lack of movement of the seals over the cylinder. My time flies! So - what do you think? Thanks, Warren |
arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 779 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
Since DOT5 doesn't absorb moisture like DOT3/4, it won't hold moisture in suspension either. If moisture does get in the system, the water (being heavier) will slowly pool at the lowest point, and can cause rust or corrosion there. I was taught that if I used DOT5 in my off road ATVs that I needed to completely disassemble and flush if I ever got one really wet, say when fording a river or deep creek.
Lo-Fi Version | Time is now: 1st July 2025 - 04:08 AM |
