worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,488 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
We run silicone brake fluid in our LBCs (Little British Cars) and this is widely accepted among that crowd. This week I am putting new front wheel cylinders in the 47 Dodge P.U. truck cause we don't run it enough and they pitted.
So why not use the silicone fluid in a 914? Yes, there is a slight compression you can feel in the pedal, but in my TR6 you can hardly feel it. I now have enough toys so that routine maintenance is a pretty big chore. Keeping up with batteries and tires is bad enough. Yes, I know that you should bleed out the old fluid, but frankly I doubt that would have helped me with the truck. The problem was the lack of movement of the seals over the cylinder. My time flies! So - what do you think? Thanks, Warren |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,192 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Early on when DOT5 was introduced, I heard stories about mold growing in/on/under it. That, and the point about water not being absorbed but simply sitting in a layer, convinced me not to try it. I'm still not using it, probably because of inertia...
--DD |
worn |
Early on when DOT5 was introduced, I heard stories about mold growing in/on/under it. That, and the point about water not being absorbed but simply sitting in a layer, convinced me not to try it. I'm still not using it, probably because of inertia... --DD Well I was a microbiologist for more than 20 years studying yeast, and knowing what those critters can do I am not surprised. But the same can be said for camera lenses in some parts of the world. As for puddling I suspect that does less damage because there are no ions or probably oxygen. But that is a guess. This is all in aid of getting the truck going to move a Lotus 907 motor. Not too German tho. |
Lo-Fi Version | Time is now: 1st July 2025 - 03:27 AM |
