> Grounding through throttle cable, Return spring burned the crap outta me! - SOLVED
clapeza
post Aug 8 2017, 07:14 PM
Got the FI back in my car (1970 1.7L) and working recently. The PO had cut the throttle cable for the carb conversion, so I installed a new TerryCable.
I noticed that the throttle cable got hot. I figured that the ground strap was corroded or broken (I can see it, but can't get to it now.)
I installed a new ground from the rearmost engine case bolt to the battery ground stud on the passenger side of the engine compartment. I used a generic 4 ga battery ground cable from my FLAPS. One end is on top of the battery ground cable. The other is on the bolt that holds the oil bath air cleaner "shelf". This end of the cable is sandwiched between 2 washers on top of the shelf arm that the bolt goes through, with the nut holding it all down tight.
I cranked the car and it ran easily, and the throttle cable was no longer hot, or even warm. Success? Not so fast...
I then replaced the bushings in the accelerator pedal bracket, so it's nice and smooth now.
Didn't get a chance to crank it because I ran out of time that day.
I cranked it today, and blipped the throttle by hand on the throttle body. I thought I saw a tiny spark at the throttle return spring where it attaches to the rear wall. I touched the spring lightly with my finger and burned the crap out of it! The engine had been running only about 10 seconds at this point.
What gives?
Theory: The new accelerator pedal bushings improved the electrical connection to the body. The new grounding cable isn't making good enough contact to the engine case, so the engine is still preferring to ground through the throttle cable.
Assumption: A 4ga cable connected from the engine case straight to the body where the battery connects is an equal (if not superior) ground compared to the transmission ground strap.
I still plan on inspecting and possibly replacing the transmission ground strap, but I'm curious as to why I burned my finger...
Ideas? Advice?
cali914
post Aug 9 2017, 09:29 AM
cali914
Yeah I heard if you don't have a transmission ground strap the grounding usually takes place through the clutch cable, and after time it will become brittle and snap.
clapeza
post Aug 9 2017, 09:56 AM
QUOTE(cali914 @ Aug 9 2017, 11:29 AM) *
I can see mine, but I'm not sure how well it's connected at both ends, and how much corrosion it has. As The Cabinetmaker said, electricity will take the path of least resistance. A nice thick ground strap that's corroded and crusty loses to a nice shiny thin throttle or transmission cable every time.
BTW, does anyone have a BTDT guide to removing and replacing the transmission ground strap? It obviously has to be done with the engine in the car, but besides groping around blindly, is there a better way?
clapeza   Grounding through throttle cable   Aug 8 2017, 07:14 PM
Racer Chris   The problem is where you have your ground attached...   Aug 8 2017, 07:21 PM
GeorgeRud   I wonder if running the ground strap from a starte...   Aug 8 2017, 08:20 PM
The Cabinetmaker   Electricity follows the path of least resistance.   Aug 8 2017, 08:28 PM
Spoke   I cranked it today, and blipped the throttle by h...   Aug 9 2017, 05:09 AM
clapeza   I cranked it today, and blipped the throttle by ...   Aug 9 2017, 06:26 AM
cali914   Yeah I heard if you don't have a transmission ...   Aug 9 2017, 09:29 AM
clapeza   Yeah I heard if you don't have a transmission...   Aug 9 2017, 09:56 AM
Mikey914   Yeah I heard if you don't have a transmission...   Aug 9 2017, 10:04 AM
Eric_Shea   The factory has a solution. It should really only...   Aug 9 2017, 10:03 AM
clapeza   The factory has a solution. It should really onl...   Aug 9 2017, 12:10 PM
Spoke   When you started your car, did the starter strain ...   Aug 9 2017, 12:55 PM
clapeza   When you started your car, did the starter strain...   Aug 9 2017, 01:13 PM
Spoke   It's the one from the rearmost case bolt in t...   Aug 9 2017, 03:18 PM
clapeza   It's the one from the rearmost case bolt in ...   Aug 9 2017, 06:48 PM
Spoke   Here's a pic of the ground strap I'm using...   Aug 9 2017, 01:05 PM
Tom_T   Clean the connections/studes & cable/strap, ...   Aug 9 2017, 04:18 PM
N_Jay   You grounded the engine, good for stating, but lef...   Aug 9 2017, 04:27 PM
Larmo63   This isn't rocket science.......   Aug 9 2017, 04:32 PM
clapeza   I replaced the transmission ground strap with a ne...   Aug 12 2017, 08:14 PM
Perry Kiehl   Was the transmission or engine case painted? Just...   Aug 13 2017, 01:09 PM
Spoke   That's really funky. Is the alternator chargin...   Aug 13 2017, 01:16 PM
clapeza   I got a ground cable exactly like the one in Spoke...   Aug 13 2017, 03:43 PM
clapeza   I did some voltage testing, all at the battery: Ca...   Aug 13 2017, 05:49 PM
Spoke   This is really weird. The entire engine case, FI c...   Aug 13 2017, 07:04 PM
76-914   Have you tried pulling one fuse at a time until th...   Aug 13 2017, 07:24 PM
Spoke   Have you tried pulling one fuse at a time until t...   Aug 14 2017, 11:01 AM
clapeza   I did some quick testing this afternoon, and came ...   Aug 16 2017, 08:08 PM
Spoke   It is possible that AAR wire is shorting to its ca...   Aug 17 2017, 04:02 AM
Racer Chris   Your plenum must be insulated from the crankcase o...   Aug 17 2017, 06:56 AM
clapeza   GOT IT!! I disconnected the wire to the A...   Aug 17 2017, 05:46 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:12 PM
