Fuel line replacement, recommendations? |
mercdev |
Nov 1 2004, 05:18 PM
Read, search, then read some more Group: Members Posts: 166 Joined: 19-July 04 From: Overland Park, KS Member No.: 2,374 |
I need to replace the lines so anyone out there have a how-to followed by a recommended brand or supplier for the correct line? I'd like to keep it stock looking if at all possible.
mikey |
Nov 1 2004, 10:39 PM
Member Group: Members Posts: 423 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None |
QUOTE Making the bends in the front of the tunnel is the tough part. I recently replaced the leaky stock fuel lines on my -6. This was a piece of cake with the engine/tranny out of the car. Don't know if this is possible with the engine still in, but I made the 45 degree bends at the gas tank ends before I put the tubing into the tunnel. I then snaked the tubing past wiring and brake lines and out of the two holes in the front of the tunnel. I angled the front of the tubing the way I wanted it and then marked an X on the back end of the tubing on the side where I needed the right angle bend in the engine compartment. I withdrew the tubing just enough to get a pipe bender on it and bent the 90 degree bends. I re inserted the tubes all the way in and put the grommets on both ends (lube up the grommets with glycerin). It was easier than I expected, but like I said the engine was out of the car. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:11 AM |
