| fduval |
Aug 12 2017, 03:57 PM
Newbie ![]() Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
On my 1973 914 2 liter, the oil temp gauge started acting crazy ( like going up and down the scale like a nut ) ???? any ideas why it is acting this weird ? flickering !!!
| McMark |
Aug 13 2017, 08:06 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Actually, the more likely wire that's failing the Green/Black wire that carries the signal from the sender in the engine sump to the gauge.
If I were testing this issue, I would make a long jumper wire and simply disconnect the sender, and install the jumper wire, then run it out from under the car and in the door and over to the gauge and connect it there (after removing the Grn/Blk). See if that solves the problem, then case the Green/Black wire to find the failure. It's probably rubbed through the insulation somewhere near the motor. There is a connector under the battery (usually in a plastic housing) and I'd inspect the length of wire from that connector to the sump sender first. |
fduval Temperature gauge going nuts! Aug 12 2017, 03:57 PM
Porschef Seems like a ground issue. Did you track down a re... Aug 12 2017, 03:59 PM
914Sixer Your wire from the sender is brittle and going ope... Aug 12 2017, 04:01 PM
fduval
Your wire from the sender is brittle and going op... Aug 12 2017, 04:04 PM
Keith914
Your wire from the sender is brittle and going o... Aug 13 2017, 08:16 AM
McMark Nope. Wire. Aug 12 2017, 04:18 PM
porschetub yep poor contact on supply wire but most likely th... Aug 12 2017, 05:52 PM
cuddyk Exactly what happened on my car. And exactly as Mc... Aug 13 2017, 11:52 AM
fduval
On my 1973 914 2 liter, the oil temp gauge sta... Aug 14 2017, 09:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 01:04 AM |
