> Need 3.2 conversion electrical help
post Aug 13 2017, 12:20 PM
914-6 GT in waiting
I can't get my fuel pump to run unless I jumper the plug for the DME relay. The car starts and runs with the connection jumped but the fuel pump then runs all the time. Just want to know where to look and what to do.
I'm very electrically challenged so you might need to really dumb it down for me. Thanks
Spoke
post Aug 13 2017, 02:14 PM
Jerry
Some tests with your voltmeter:
put a small wire in the socket at 85b then install the relay.
Turn the car on or crank and measure 85b to ground. I think it should be 0V.
Put a small wire in the socket at 87 then install the relay.
Turn the car on or crank and measure 87 to ground. Should be 12V.
mepstein   Need 3.2 conversion electrical help   Aug 13 2017, 12:20 PM
Steve   You did try another dme relay? Otherwise the Bent...   Aug 13 2017, 01:06 PM
Spoke   I had a similar problem on my 930. Engine would ru...   Aug 13 2017, 01:21 PM
mepstein   Tried 4 new relays. One was solid state. Flummoxe...   Aug 13 2017, 01:30 PM
Spoke   Tried 4 new relays. One was solid state. Flummox...   Aug 13 2017, 02:04 PM
porschetub   The solder joints can also fail on them too,pop th...   Aug 13 2017, 01:36 PM
mepstein   The solder joints can also fail on them too,pop t...   Aug 13 2017, 01:45 PM
Spoke   I jumper the plug for the DME relay. Which pins...   Aug 13 2017, 02:11 PM
Spoke   Some tests with your voltmeter: put a small wire ...   Aug 13 2017, 02:14 PM
Steve   This manual is awesome!!   Aug 13 2017, 03:34 PM
Steve   RE: Need 3.2 conversion electrical help   Aug 13 2017, 03:36 PM
Steve   RE: Need 3.2 conversion electrical help   Aug 13 2017, 03:42 PM
jim912928   I hate wiring...do you have the red wire (fuel pum...   Aug 13 2017, 06:38 PM
mepstein   I hate wiring...do you have the red wire (fuel pu...   Aug 13 2017, 06:42 PM
Spoke   Looks like a pretty simple circuit: 1) Ignition k...   Aug 13 2017, 07:20 PM
mepstein   I know the dme is good. Runs fine in other cars.   Aug 13 2017, 08:30 PM
Steve   Do what Spoke suggested and put an ohm Meter on pi...   Aug 13 2017, 09:24 PM
mepstein   Do what Spoke suggested and put an ohm Meter on p...   Aug 13 2017, 09:46 PM
shoguneagle   Do not over look the DME Relay socket itself; shor...   Aug 13 2017, 10:02 PM
McMark   If you've tried the DME in other cars and they...   Aug 14 2017, 07:02 AM
jim912928   The AFM point is a good one. Before I put my 3.2l ...   Aug 16 2017, 05:30 PM
Spoke   Mark and Ray stopped by my house today to do some ...   Aug 19 2017, 09:27 PM
timothy_nd28   Things to do to finish the install: 1) Figure out...   Aug 22 2017, 09:12 AM
mepstein   Huge step to have the engine start with the turn o...   Aug 20 2017, 08:08 AM
Cairo94507   Glad to hear you resolved that issue and will be d...   Aug 20 2017, 08:23 AM
jim912928   congrats!   Aug 20 2017, 10:24 AM
- Lo-Fi Version Time is now: 10th October 2026 - 07:34 AM
