| mepstein |
Aug 13 2017, 12:20 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,927 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I can't get my fuel pump to run unless I jumper the plug for the DME relay. The car starts and runs with the connection jumped but the fuel pump then runs all the time. Just want to know where to look and what to do.
I'm very electrically challenged so you might need to really dumb it down for me. Thanks |
| Spoke |
Aug 13 2017, 07:20 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,432 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Looks like a pretty simple circuit:
1) Ignition key provides power to 86; 85 is ground thus top relay should turn on. 2) With top relay on, battery voltage from 30 connects to 87; 87 should be 12V. 3) 87 is also top of bottom relay coil; 85b from DME must be grounded to power bottom relay; bottom relay provides path from battery (pin 30) to 87b. Tests: Jam a small wire in plug for 87, install relay, turn ignition on, test 87 to ground; measure 12V Once 87 verified at 12V: Jam a small wire in plug for 85b, install relay, turn ignition on and/or crank the engine, test 85b to ground; measure 0V. DME should provide ground at 85b. If not, the issue is with the DME. |
mepstein Need 3.2 conversion electrical help Aug 13 2017, 12:20 PM
Steve You did try another dme relay? Otherwise the Bent... Aug 13 2017, 01:06 PM
Spoke I had a similar problem on my 930. Engine would ru... Aug 13 2017, 01:21 PM
mepstein Tried 4 new relays. One was solid state.
Flummoxe... Aug 13 2017, 01:30 PM
Spoke
Flummox... Aug 13 2017, 02:04 PM
porschetub The solder joints can also fail on them too,pop th... Aug 13 2017, 01:36 PM
The solder joints can also fail on them too,pop t... Aug 13 2017, 01:45 PM
Spoke
Which pins... Aug 13 2017, 02:11 PM
Spoke Some tests with your voltmeter:
put a small wire ... Aug 13 2017, 02:14 PM
Steve This manual is awesome!!
Aug 13 2017, 03:34 PM
Steve RE: Need 3.2 conversion electrical help Aug 13 2017, 03:36 PM
Steve RE: Need 3.2 conversion electrical help Aug 13 2017, 03:42 PM
jim912928 I hate wiring...do you have the red wire (fuel pum... Aug 13 2017, 06:38 PM
I hate wiring...do you have the red wire (fuel pu... Aug 13 2017, 06:42 PM
mepstein I know the dme is good. Runs fine in other cars. Aug 13 2017, 08:30 PM
Steve Do what Spoke suggested and put an ohm Meter on pi... Aug 13 2017, 09:24 PM
Do what Spoke suggested and put an ohm Meter on p... Aug 13 2017, 09:46 PM
shoguneagle Do not over look the DME Relay socket itself; shor... Aug 13 2017, 10:02 PM
McMark If you've tried the DME in other cars and they... Aug 14 2017, 07:02 AM
jim912928 The AFM point is a good one. Before I put my 3.2l ... Aug 16 2017, 05:30 PM
Spoke Mark and Ray stopped by my house today to do some ... Aug 19 2017, 09:27 PM
timothy_nd28
Things to do to finish the install:
1) Figure out... Aug 22 2017, 09:12 AM
mepstein Huge step to have the engine start with the turn o... Aug 20 2017, 08:08 AM
Cairo94507 Glad to hear you resolved that issue and will be d... Aug 20 2017, 08:23 AM
jim912928 congrats! Aug 20 2017, 10:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th October 2026 - 08:24 AM |
