| thelogo |
Aug 11 2017, 10:10 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Its get wet around the
Gold tee and surrounding 3 closest clamps And will drip a nice puddle but as soon as the car is running driving Drip go's away , even after turning off the car and restarting Never comes back until the next sunday drive . But then there it is again Bolt clamps are swiveled around So i cant really reach them |
| 76-914 |
Aug 12 2017, 07:27 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,826 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
(IMG:style_emoticons/default/agree.gif) & Is the Tee a barbed fitting or threaded fitting? Is the rubber stiff? What is that yellow ring? Hint: Take a piece of a paper towel and wrap around each joint. Pressurize and quickly check for wet spots on paper towel. One pin head drop of gas will make a quarter sized splotch on the paper. Makes it quick and easy to locate which one is leaking. (IMG:style_emoticons/default/beerchug.gif)
| thelogo |
Aug 13 2017, 11:00 PM
(IMG:style_emoticons/default/agree.gif) & Is the Tee a barbed fitting or threaded fitting? Is the rubber stiff? What is that yellow ring? Hint: Take a piece of a paper towel and wrap around each joint. Pressurize and quickly check for wet spots on paper towel. One pin head drop of gas will make a quarter sized splotch on the paper. Makes it quick and easy to locate which one is leaking. (IMG:style_emoticons/default/beerchug.gif) When i pressurize i assume you me turn on the car or Put it to the on postion so fuel pump runs up ??? Because if i just run pump before cranking key No leak (IMG:style_emoticons/default/bye1.gif) |
| Elliot Cannon |
Aug 13 2017, 11:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
(IMG:style_emoticons/default/agree.gif) & Is the Tee a barbed fitting or threaded fitting? Is the rubber stiff? What is that yellow ring? Hint: Take a piece of a paper towel and wrap around each joint. Pressurize and quickly check for wet spots on paper towel. One pin head drop of gas will make a quarter sized splotch on the paper. Makes it quick and easy to locate which one is leaking. (IMG:style_emoticons/default/beerchug.gif) When i pressurize i assume you me turn on the car or Put it to the on postion so fuel pump runs up ??? Because if i just run pump before cranking key No leak (IMG:style_emoticons/default/bye1.gif) What kind of fuel pump are you using and what is the output pressure. It shouldn't be more than about 3 1/2 PSI with carbs. |
| thelogo |
Aug 13 2017, 11:22 PM
(IMG:style_emoticons/default/agree.gif) & Is the Tee a barbed fitting or threaded fitting? Is the rubber stiff? What is that yellow ring? Hint: Take a piece of a paper towel and wrap around each joint. Pressurize and quickly check for wet spots on paper towel. One pin head drop of gas will make a quarter sized splotch on the paper. Makes it quick and easy to locate which one is leaking. (IMG:style_emoticons/default/beerchug.gif) When i pressurize i assume you me turn on the car or Put it to the on postion so fuel pump runs up ??? Because if i just run pump before cranking key No leak (IMG:style_emoticons/default/bye1.gif) What kind of fuel pump are you using and what is the output pressure. It shouldn't be more than about 3 1/2 PSI with carbs. Useing a rotary fuel pump , supposed to be 3 to 5 psi . Lets assume for a minute that they were passed v1 And handle the problem in the air and Are able to get engine shut down and fire doesn't cause the plane to explode . Could the concord fly with a engine out and circle around back to land or plane was so far gone that no matter what level of pilot skill could overcome the Crash |
thelogo Bleeping Fuel leak only on start up / warm up Aug 11 2017, 10:10 PM
thelogo :worship: Aug 11 2017, 10:20 PM
thelogo It get soaked in gas dripps a little then seals up... Aug 11 2017, 10:21 PM
JawjaPorsche Replace those clamps with fuel injection clamps. ... Aug 12 2017, 05:13 AM
thelogo
Replace those clamps with fuel injection clamps. ... Aug 12 2017, 07:21 AM
Replace those clamps with fuel injection clamps.... Aug 12 2017, 08:05 AM
mepstein :agree: Need proper clamps and the hose might be... Aug 12 2017, 05:26 AM
rhodyguy What is that white line on the verticle hose in po... Aug 13 2017, 11:54 AM
Elliot Cannon Replace them. Replace them all. NOW. New prope... Aug 13 2017, 10:17 PM
thelogo
Replace them. Replace them all. NOW. New prop... Aug 13 2017, 10:40 PM
Elliot Cannon The decision to continue take off or abort the tak... Aug 13 2017, 11:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th December 2025 - 08:52 PM |
