| tornik550 |
Aug 17 2017, 12:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have been quite busy with life lately and haven't had any time to work on my car. I drove it into my barn yesterday. I recently replaced my complete front suspension with a 87 911 front suspension. I took off my rear suspension to do a 5 lug conversion. My car did have a few alignment shims in the rear when I removed the suspension however I forgot to add them back when I reinstalled the suspension. The camber visibly looks ok. Obviously need to get an alignment however it is a fairly long drive to the place that I trusT so I would like to get the car reasonably leveled out before driving it far. The car drives straight.
What adjustments would increase the ground clearance on the right front? Will adding the alignment shims to the right rear increase the ground clearance on the right rear? I am fairly embarrassed to ask these questions. I obviously am not very adept at working on suspensions. I guess I could drive it the way it is- everyone will think I have hydraulics! |
| mepstein |
Aug 17 2017, 01:05 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,662 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Have you driven it yet. Shocks need some miles to settle in. If you had one side jacked up for each shock replacement, it will be off untill you drive it. Also, every time you exit the car, you will unweight the driver side and the car might look a little uneven.
tornik550 Right side of car lower than left after suspension replacement. Aug 17 2017, 12:57 PM
infraredcalvin Definitely be sure the suspension is settled, ther... Aug 17 2017, 01:32 PM
mgphoto
Definitely be sure the suspension is settled, the... Aug 17 2017, 04:27 PM
burton73 Get a tape measure and make the adjustment on the ... Aug 17 2017, 02:36 PM
burton73 From Dave at the Bird: Part # 17, "adjusting ... Aug 17 2017, 04:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 02:07 AM |
