> Boxster calipers. Question for those that have done the swap
twistedstang
post Aug 18 2017, 05:00 PM
So, for those of you that have done the boxster caliper swap and have some miles on your car, how do you like the swap?
Also, have you done the fronts only, or front and rear? What master cylinder are you using?
I'm just looking for some real world feedback from the cars that made it off the jackstands.
Steve
post Aug 18 2017, 05:47 PM
I'm running them front and rear courtesy of Rich Johnson. I love them. Awesome braking and quiet. It's been about 5 years now. I don't track it, so I am on the same set of pads. I am running a "T", no proportioning valve. I have autocrossed it a couple of times and slammed on the brakes several times on the street and in an autocross and I have never had the rears lock up first. I am also running a 911 emergency brake, since it's mainly a street car.
Im also running a 19mm master cylinder. Works fine
twistedstang   Boxster calipers. Question for those that have done the swap   Aug 18 2017, 05:00 PM
Andyrew   Thats a lot of caliper for a 914. Note that it nee...   Aug 18 2017, 05:26 PM
mepstein   We do it a lot on the 911 builds with 3.2 or 3.6 s...   Aug 18 2017, 05:32 PM
Steve   I'm running them front and rear courtesy of Ri...   Aug 18 2017, 05:47 PM
tygaboy   Tony (Cracker) has them on his car and has said ho...   Aug 18 2017, 05:51 PM
Retroracer   So, for those of you that have done the boxster c...   Aug 18 2017, 06:15 PM
SirAndy   I have them front and rear. Best thing i ever did ...   Aug 18 2017, 06:53 PM
burton73   I have fronts and rears bought from Rich Johnston ...   Aug 18 2017, 07:13 PM
Cracker   I would say it is a great upgrade no matter how yo...   Aug 18 2017, 07:40 PM
phillstek   Would be overkill on a stock powered 4 unless you ...   Aug 19 2017, 02:26 AM
twistedstang   Thanks for the reply's guys. It just seems t...   Aug 19 2017, 10:58 AM
Cracker   Not that it matters to me what calipers you instal...   Aug 19 2017, 02:37 PM
phillstek   Not that it matters to me what calipers you insta...   Aug 20 2017, 02:56 AM
twistedstang   Not that it matters to me what calipers you inst...   Aug 20 2017, 05:55 AM
Cracker   LOL - Got it. Do the upgrade...for the money, it i...   Aug 20 2017, 06:16 AM
twistedstang   Not that it matters to me what calipers you insta...   Aug 20 2017, 05:47 AM
Andyrew   Mine might have been taken as negative. Which is t...   Aug 19 2017, 05:03 PM
mepstein   Mine might have been taken as negative. Which is ...   Aug 19 2017, 05:18 PM
Cracker   I have only used the Rebel Racing adapters (I am n...   Aug 19 2017, 06:34 PM
timothy_nd28   I have a early 911 front end setup with 2.5" ...   Aug 19 2017, 09:20 PM
Porschef   I have a early 911 front end setup with 2.5...   Aug 20 2017, 06:07 AM
Cracker   Is this a trick question? I could be wrong but the...   Aug 20 2017, 06:19 AM
mepstein   I have a early 911 front end setup with 2.5...   Aug 20 2017, 06:41 AM
Cracker   DUH! Stupid me...that is correct. I was equate...   Aug 20 2017, 06:54 AM
mgp4591   Test fitting the rears - already have the fronts...   Aug 20 2017, 12:09 AM
craig downs   I did a front and rear boxter caliper conversion a...   Aug 20 2017, 09:58 AM
mepstein   I did a front and rear boxter caliper conversion ...   Aug 20 2017, 10:54 AM
timothy_nd28   You are correct Mark, I just measured them and the...   Aug 20 2017, 02:09 PM
- Lo-Fi Version Time is now: 8th December 2025 - 08:13 PM
