timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
What is this F-log adapter? Where can you buy them or what parts are used for a work around? Thanks in advance
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
What is this F-log adapter? Where can you buy them or what parts are used for a work around? Thanks in advance ![]() Water pump on the cool side only? hmmmm, seems like it would last longer with less heat. Thats why they say to run the water pump on the cool side. Thats what I did. On topic it looks like the f log adapter just converts the two block outputs to a single line to run to the radiator. |
Mueller |
What is this F-log adapter? Where can you buy them or what parts are used for a work around? Thanks in advance Water pump on the cool side only? hmmmm, seems like it would last longer with less heat. Thats why they say to run the water pump on the cool side. Thats what I did. On topic it looks like the f log adapter just converts the two block outputs to a single line to run to the radiator. Similar to this guys stuff? http://toy-jet.com/Index119.html I'm going to make something similar for mine. |
Lo-Fi Version | Time is now: 31st July 2025 - 01:48 AM |
