| twistedstang |
Aug 18 2017, 05:00 PM
Member ![]() ![]() Group: Members Posts: 229 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None
So, for those of you that have done the boxster caliper swap and have some miles on your car, how do you like the swap?
Also, have you done the fronts only, or front and rear? What master cylinder are you using? I'm just looking for some real world feedback from the cars that made it off the jackstands. |
| craig downs |
Aug 20 2017, 09:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
I did a front and rear boxter caliper conversion a few years ago. I used some early 911 struts with 3" spacing. I made my own mounts and had to do some machining on the struts to make them work and the thread is somewhere on here. I love the brakes as they are very powerful. I ran a 19mm master cylinder at first but put on a 23mm later. I tend to like the feel with the 19 better as it takes less effort on the foot but has more pedal travel. My rims are 15" deep 6s with hearts and the fit and I left the stock valve on for the rears.
twistedstang Boxster calipers. Question for those that have done the swap Aug 18 2017, 05:00 PM
Andyrew Thats a lot of caliper for a 914. Note that it nee... Aug 18 2017, 05:26 PM
mepstein We do it a lot on the 911 builds with 3.2 or 3.6 s... Aug 18 2017, 05:32 PM
Steve I'm running them front and rear courtesy of Ri... Aug 18 2017, 05:47 PM
tygaboy Tony (Cracker) has them on his car and has said ho... Aug 18 2017, 05:51 PM
Retroracer
So, for those of you that have done the boxster c... Aug 18 2017, 06:15 PM
SirAndy I have them front and rear. Best thing i ever did ... Aug 18 2017, 06:53 PM
burton73 I have fronts and rears bought from Rich Johnston ... Aug 18 2017, 07:13 PM
Cracker I would say it is a great upgrade no matter how yo... Aug 18 2017, 07:40 PM
phillstek Would be overkill on a stock powered 4 unless you ... Aug 19 2017, 02:26 AM
twistedstang Thanks for the reply's guys. It just seems t... Aug 19 2017, 10:58 AM
Cracker Not that it matters to me what calipers you instal... Aug 19 2017, 02:37 PM
phillstek
Not that it matters to me what calipers you insta... Aug 20 2017, 02:56 AM
twistedstang
Not that it matters to me what calipers you inst... Aug 20 2017, 05:55 AM
Cracker LOL - Got it. Do the upgrade...for the money, it i... Aug 20 2017, 06:16 AM
twistedstang
Not that it matters to me what calipers you insta... Aug 20 2017, 05:47 AM
Andyrew Mine might have been taken as negative. Which is t... Aug 19 2017, 05:03 PM
Mine might have been taken as negative. Which is ... Aug 19 2017, 05:18 PM
Cracker I have only used the Rebel Racing adapters (I am n... Aug 19 2017, 06:34 PM
timothy_nd28 I have a early 911 front end setup with 2.5" ... Aug 19 2017, 09:20 PM
Porschef
I have a early 911 front end setup with 2.5... Aug 20 2017, 06:07 AM
Cracker Is this a trick question? I could be wrong but the... Aug 20 2017, 06:19 AM
I have a early 911 front end setup with 2.5... Aug 20 2017, 06:41 AM
Cracker DUH! Stupid me...that is correct. I was equate... Aug 20 2017, 06:54 AM
mgp4591
Test fitting the rears - already have the fronts... Aug 20 2017, 12:09 AM
I did a front and rear boxter caliper conversion ... Aug 20 2017, 10:54 AM
timothy_nd28 You are correct Mark, I just measured them and the... Aug 20 2017, 02:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 08:12 PM |
