> Welcome to the slippery slope..., Porsche 6-cylinder conversion
Optimusglen
post Jun 15 2017, 09:21 AM
15 months ago I bought a crusty old 1971 914-4 that had been sitting in a garage for 20 years getting peed and chewed on by all sorts of creatures.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1497540074.1.jpg)
I started the project with a plan of it being driveable at the 1 year mark. Since then I've done an engine build, carb rebuild, brake rebuild with 5-lug swap, fuel system rebuild, interior rebuild, suspension rebuild, and some general freshening up. Oh, I forgot to mention that my wife and I had a baby too, safe to say it's been a pretty busy 15 months.
Here's the build thread if anyone's interested.
http://www.914world.com/bbs2/index.php?sho...=277349&hl=
Anyway, the result is good. It's running and driving, the 1911 is strong and runs well. Handles great considering there are no sway bars. Tail shifter is as vague as you imagine though, and the engine is still sub 100hp so it's not incredibly fast.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1496565572.1.jpg)
It's first real public appearance was at the June C&C that I attended with a good friend in his 911.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1497540075.2.jpg)
Exiting a cloverleaf he pulled away like I was standing still. To add insult to injury a minivan pulled away too. This lit a little spark, I wanted more power. I started crunching numbers for building the type 4, goal is around 150hp. Can you get 150hp in a type 4 that's home built? Sure, lots of people have done it. But there's an even better, more expensive and headache inducing option...
A friend of mine owns Flat Six in Minneapolis, MN. About 40 minutes from me. Sent him a message inquiring about core 6 cylinders and ended up coming home with this.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1497540075.3.jpg)
It's a 2.2 from a 911T, the 125hp version. On top are a pair of Zenith carbs that will work fine for my purposes after a complete rebuild. It turns over smoothly and you can feel when it comes up on compression. Good signs for an otherwise unknown engine. If you had followed along in my build thread you'll know that I got some amazing deals, both for parts and for the car itself. The 6 does not disappoint in that regard, but I wont be sharing the details here.
Perhaps the best part of the deal is that he said if I get into it and find that anything is FUBAR, I can get a no-charge replacement from him since he has Parted several 2.2's. Again, this is a friend, I don't expect him to do this for anyone.
With his help we laid out a build plan. Going to get the T cams reground to the E profiles paired with higher compression pistons. Cylinders are iron so I can bore those. Goal is around 150ish hp. It'll be a "budget" build in the sense that I'm not going for huge power and will be doing the assembly/cleaning myself. I won't be cutting corners with machine work and inspection though.
I will be mating it with a side-shift trans using the early 911 flywheel. flywheel and bulkhead weld-in mount already on order. It's not likely that I'll be doing a conventional 914-6 oil tank, it just seems like so much money for what you get. We will see though, as time progresses I may change my mind.
This will be a driver, not trying to make it a show queen or original to a real 914-6. I want to keep the utility of both trunks but I want the mechanicals to be functionally excellent.
Time frame is significantly longer than the original build. Planning at least a year or two considering the work and money involved. I'll update this thread moving forward and not my original build thread, kind of a new chapter if you will.
Fortunately the 914 is perfectly driveable while I collect and rebuild. (IMG:style_emoticons/default/smile.gif)
So here's to the next chapeter, however expensive and time consuming it may be.
(IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-19709-1497540075.4.gif)
porschetub
post Aug 23 2017, 01:36 AM
Running stockish 2.2 T headers and upgraded ignition,
30mm vents .
125 mains,
52 idles,
air correctors are stock,
going really well as per last tune,not hard to set up if you do bench tuning before,set up pump jets and general setting first.
You can get more power from these carbs ,lots of parts for them now too.
Edit more to add;
My research indicated these were more of a emissions carb hence the small stock venturies and matching small main and idle jets,a quick calculation got me to use 30mm venturies which are pretty much spot on for 2.2 litre capacity.
Main wear points are the spindles themselves,the bushes seem to hold up well enough,the ends of the pump rods wear in the pivots as do the throttle cam roller pins.
Be very careful with the small steel air bleed screws,if seized they can break very easily,PO of my carbs had broken one off so I had to drill it out...rather scary.
The accelerator pump spray jets can be blocked ,I found 2 were that way on my left carb,found that out when I bench tested with full fuel bowls.
Buy the PMO made float level tool as it is handy for checking bowl fuel levels and needle and seat operation.
You can pretty much buy all the parts but looks like you have a few spares ,good luck (IMG:style_emoticons/default/beer.gif) .
Optimusglen   Welcome to the slippery slope...   Jun 15 2017, 09:21 AM
Tom_T   Quite a change! :trophy: Enjoy! :driving...   Jun 15 2017, 09:30 AM
Alphaogre   http://www.914world.com/bbs2/uploads_offsite/i.img...   Jun 15 2017, 09:47 AM
Steve   It's only money and time and lots of it, but w...   Jun 15 2017, 10:10 AM
mb911   I can provide you a 6 tank kit for $350 if yo...   Jun 15 2017, 10:24 AM
forrestkhaag   Your plan is solid /drive while collecting parts i...   Jun 15 2017, 10:35 AM
Mueller   Great looking car, doing a "stockish" Ty...   Jun 15 2017, 12:12 PM
mb911   I suppose i should add that i always have second o...   Jun 15 2017, 02:11 PM
Optimusglen   I suppose i should add that i always have second ...   Jun 15 2017, 02:33 PM
porschetub   I suppose i should add that i always have second...   Jun 15 2017, 04:24 PM
mb911   I suppose i should add that i always have second...   Jun 15 2017, 08:05 PM
porschetub   I suppose i should add that i always have second...   Jun 15 2017, 10:47 PM
mepstein   The stock 914-6 tank is a really nice way to handl...   Jun 15 2017, 04:52 PM
Krieger   Your sick, very sick! Good luck with the buil...   Jun 15 2017, 09:25 PM
Nie Zu Alt   Good luck with the build! I'll be followin...   Jun 15 2017, 09:43 PM
Larmo63   Many of us are doing /6 conversions right now. We ...   Jun 15 2017, 10:52 PM
Optimusglen   Started the teardown and did some much needed gara...   Jun 17 2017, 01:54 PM
porschetub   Started the teardown and did some much needed gar...   Jun 17 2017, 08:19 PM
mb911   [quote name='Optimusglen' post='2497598' date='Ju...   Jun 18 2017, 07:22 AM
mepstein   [quote name='porschetub' post='2497711' date='Jun...   Jun 19 2017, 10:05 AM
mb911   At least your car is 1 piece. My engine is still a...   Jun 17 2017, 03:48 PM
pete-stevers   You will not regret this conversion... However a n...   Jun 17 2017, 09:33 PM
colingreene   So your friends with Chris, His 911 looks so good ...   Jun 19 2017, 09:37 AM
Optimusglen   So your friends with Chris, His 911 looks so good...   Jun 22 2017, 11:23 AM
Optimusglen   Started a little bit of the tear down. Head studs ...   Jun 22 2017, 09:24 AM
mb911   Started a little bit of the tear down. Head studs...   Jun 22 2017, 09:32 AM
Optimusglen   After talking with someone who's been building...   Jul 6 2017, 01:50 PM
mb911   Yup I am actually using mechanical adjusters and r...   Jul 6 2017, 02:43 PM
iwanta914-6   You are nuts! LOL You had this car on the roa...   Jul 6 2017, 03:20 PM
Optimusglen   You are nuts! LOL You had this car on the ro...   Jul 6 2017, 06:55 PM
Mark Henry   There is a way to make the Carrera tensioners no f...   Jul 6 2017, 04:26 PM
Mark Henry   I'd seriously take Ben up on his offer, the pr...   Jul 6 2017, 04:31 PM
Optimusglen   I'd seriously take Ben up on his offer, the p...   Jul 6 2017, 07:09 PM
Larmo63   I doubt if I will do Carrera tensioners. Slipper...   Jul 6 2017, 09:10 PM
mb911   I doubt if I will do Carrera tensioners. Slippe...   Jul 7 2017, 08:53 AM
burton73   I doubt if I will do Carrera tensioners. Slipp...   Jul 14 2017, 01:16 PM
rgalla9146   [quote name='mb911' post='2503823' date='Jul 7 20...   Feb 27 2018, 04:21 PM
GeorgeRud   I'd at least recommend using some tensioner co...   Jul 6 2017, 09:22 PM
Optimusglen   I'd at least recommend using some tensioner c...   Jul 7 2017, 07:49 AM
Mark Henry   I'd at least recommend using some tensioner c...   Jul 7 2017, 08:28 AM
Mark Henry   BTW and just an FYI Ben would have given you a bet...   Jul 7 2017, 08:34 AM
mb911   BTW and just an FYI Ben would have given you a be...   Jul 7 2017, 08:52 AM
Optimusglen   BTW and just an FYI Ben would have given you a be...   Jul 7 2017, 08:55 AM
Mark Henry   ... proper case savers installed (I will probably...   Jul 7 2017, 09:28 AM
Optimusglen   Case savers have to be done on a mill, I've ...   Jul 7 2017, 09:33 AM
mb911   So one option for tensioners when talking extensiv...   Jul 7 2017, 09:01 AM
Mark Henry   That's great...but I bet you still go over bud...   Jul 7 2017, 09:58 AM
Optimusglen   That's great...but I bet you still go over bu...   Jul 7 2017, 10:08 AM
Mark Henry   That's great...but I bet you still go over b...   Jul 7 2017, 11:25 AM
mb911   [quote name='Optimusglen' post='2503842' date='Ju...   Jul 7 2017, 02:43 PM
jcambo7   :popcorn: I have a 70's 911T in my 914. If y...   Jul 7 2017, 05:25 PM
Optimusglen   Yesterday I made the drive to a friends to pick up...   Jul 13 2017, 09:30 AM
Optimusglen   Tore down a bit more. #4/5/6 pistons, cylinders, a...   Jul 14 2017, 08:37 AM
Justinp71   :Qarl: Hard too beat the sound and feel of the ...   Jul 14 2017, 10:10 AM
mb911   :agree: I get all my parts from Henry and he just...   Jul 14 2017, 10:37 AM
mb911   Did you find any chunk s in the sump screen?   Jul 14 2017, 10:38 AM
Optimusglen   screen is clear of any/all chunks. Yeah I have ti...   Jul 14 2017, 10:44 AM
bigkensteele   screen is clear of any/all chunks. Yeah I have t...   Jul 14 2017, 12:51 PM
Optimusglen   What would be considered high compression? I hav...   Jul 14 2017, 02:22 PM
mb911   screen is clear of any/all chunks. Yeah I have t...   Jul 14 2017, 04:23 PM
Larmo63   I would be quite happy with what you found on the ...   Jul 14 2017, 07:51 PM
JmuRiz   Looks lucky thus far. My previously rebuilt 2.7 co...   Jul 15 2017, 07:37 AM
Optimusglen   Case split, nothing scary! http://www.914worl...   Jul 15 2017, 07:49 PM
bretth   Case split, nothing scary! Nothing scary bu...   Jul 15 2017, 10:55 PM
Optimusglen   Case split, nothing scary! Nothing scary b...   Jul 16 2017, 05:33 AM
mb911   Case split, nothing scary! Nothing scary b...   Jul 16 2017, 08:17 AM
mepstein   Case split, nothing scary! Nothing scary b...   Jul 18 2017, 01:32 PM
bretth   [quote name='bretth' post='2506818' date='Jul 16 ...   Jul 18 2017, 01:44 PM
GeorgeRud   I took the easy way and had Henry rebuild my 2.7, ...   Jul 16 2017, 08:59 AM
mb911   I took the easy way and had Henry rebuild my 2.7,...   Jul 16 2017, 10:40 AM
Optimusglen   Initial inspection and measurement taking tonight....   Jul 18 2017, 01:14 PM
Optimusglen   Good news! Crank journals are all perfectly in...   Jul 18 2017, 08:38 PM
mb911   Good news is that rebuilt rods are fairly inexpens...   Jul 19 2017, 02:52 PM
Optimusglen   Ok, been a long time without an update. Picked up...   Aug 22 2017, 09:09 AM
iamchappy   I'd love to stop in while your slapping it tog...   Aug 22 2017, 03:07 PM
Optimusglen   I'd love to stop in while your slapping it to...   Aug 22 2017, 03:27 PM
iamchappy   I'm pretty good but not great at body work, an...   Aug 22 2017, 06:36 PM
porschetub   Running stockish 2.2 T headers and upgraded igniti...   Aug 23 2017, 01:36 AM
Optimusglen   I've been collecting parts, i.e. all the beari...   Sep 11 2017, 09:01 AM
Optimusglen   Update time, been holding off on moving too far fo...   Nov 6 2017, 08:33 AM
Optimusglen   Been awhile since I've posted any project news...   Feb 27 2018, 08:26 AM
mb911   Been awhile since I've posted any project new...   Feb 27 2018, 09:03 AM
Optimusglen   In your experience was it 1.625 I.D. or O.D. ? W...   Feb 27 2018, 10:25 AM
mb911   In your experience was it 1.625 I.D. or O.D. ? ...   Feb 27 2018, 11:48 AM
Optimusglen   Thanks for the feedback, I have some messages out ...   Feb 27 2018, 11:54 AM
mb911   Thanks for the feedback, I have some messages out...   Feb 27 2018, 12:11 PM
Optimusglen   Looks like I'll be holding onto these until th...   Feb 27 2018, 12:37 PM
Optimusglen   Update: Today I went out and did a test assembly o...   Apr 5 2018, 12:00 PM
BK911   2.4 crank and rods.   Apr 5 2018, 01:06 PM
mb911   I am sorry to hear that.. :(   Apr 5 2018, 04:05 PM
Optimusglen   I am sorry to hear that.. :( It's ok, it...   Apr 6 2018, 08:03 AM
gereed75   My experience is that main bearing bores ovalize a...   Apr 6 2018, 09:56 AM
Optimusglen   Thought I should update the thread. I got my head...   Apr 25 2018, 08:25 AM
- Lo-Fi Version Time is now: 24th November 2026 - 03:24 AM
