burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,882 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
I have questioned whether I should put the 86 Corvette Engine in my 914 or buying an LS 1 to 5 Engine to mate up to my 930 box.
If I stay with my 86 Vette engine that I have, I will have to get a newer injection system and a distributor and have my fresh crate stock 86 engine re-worked for the GM Hot cam kit. I will have to have a machine shop work the heads so the push rods clear and set everything up and dyno tune it so it is plug and play for me. I do not want to put an engine in more than one time. The full clutch and adapter stuff is new Kennedy Eng. For a 350 and the Turbo 930 trans so I do not know if that would need to be changed to fit the LS? I am trying to see where I am at with money and work to be done. What about the starter for the LS? The intake for a LS would need to be turned 180 degrees so it can get air from the rear trunk as I believe there is not enough room in the front of engine to the rear fire wall. I am going with a Cable Shift brand shifter and linkages. I have mufflers from a Ferrari like Drivability had in his old 350 with a 930 trans. Hit a vacuum and the mufflers open up the baffles. Kind of what I had in my 2015 Corvette. I guess the LS would be drive by wire and that can help me out. Bob B |
Lo-Fi Version | Time is now: 4th September 2025 - 12:22 AM |
