burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,882 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
I have questioned whether I should put the 86 Corvette Engine in my 914 or buying an LS 1 to 5 Engine to mate up to my 930 box.
If I stay with my 86 Vette engine that I have, I will have to get a newer injection system and a distributor and have my fresh crate stock 86 engine re-worked for the GM Hot cam kit. I will have to have a machine shop work the heads so the push rods clear and set everything up and dyno tune it so it is plug and play for me. I do not want to put an engine in more than one time. The full clutch and adapter stuff is new Kennedy Eng. For a 350 and the Turbo 930 trans so I do not know if that would need to be changed to fit the LS? I am trying to see where I am at with money and work to be done. What about the starter for the LS? The intake for a LS would need to be turned 180 degrees so it can get air from the rear trunk as I believe there is not enough room in the front of engine to the rear fire wall. I am going with a Cable Shift brand shifter and linkages. I have mufflers from a Ferrari like Drivability had in his old 350 with a 930 trans. Hit a vacuum and the mufflers open up the baffles. Kind of what I had in my 2015 Corvette. I guess the LS would be drive by wire and that can help me out. Bob B |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Bob,
My choice was the LS1 for all its electronic controls. The driveability is fantastic, starts in an instant (regardless of weather), and gets really good mileage. Mine is mated to an Audi 01e 6 speed transaxle. The LS1, LS6, and the L33 are all good choices as they have aluminum blocks. There are others too; check Wiki for the latest. There are a few here who are in the process of, or have built 914/LSx's, so there is plenty of experience to draw from. Andys |
Lo-Fi Version | Time is now: 4th September 2025 - 12:24 AM |
