> Question on the rotating 180 degrees of LS injection intake, Better to go with a LS or a built 86 GM 350?
burton73
post Aug 24 2017, 01:35 PM
Senior member, and old dude
I have questioned whether I should put the 86 Corvette Engine in my 914 or buying an LS 1 to 5 Engine to mate up to my 930 box.
If I stay with my 86 Vette engine that I have, I will have to get a newer injection system and a distributor and have my fresh crate stock 86 engine re-worked for the GM Hot cam kit. I will have to have a machine shop work the heads so the push rods clear and set everything up and dyno tune it so it is plug and play for me. I do not want to put an engine in more than one time.
The full clutch and adapter stuff is new Kennedy Eng. For a 350 and the Turbo 930 trans so I do not know if that would need to be changed to fit the LS?
I am trying to see where I am at with money and work to be done.
What about the starter for the LS?
The intake for a LS would need to be turned 180 degrees so it can get air from the rear trunk as I believe there is not enough room in the front of engine to the rear fire wall.
I am going with a Cable Shift brand shifter and linkages. I have mufflers from a Ferrari like Drivability had in his old 350 with a 930 trans. Hit a vacuum and the mufflers open up the baffles. Kind of what I had in my 2015 Corvette.
I guess the LS would be drive by wire and that can help me out.
Bob B
burton73
post Aug 24 2017, 04:25 PM
My 86 corvette Eng. has aluminum heads and weights 60 lb. less that an iron head V8
Not sure what the all aluminum engine weights?
Bob B
- Lo-Fi Version Time is now: 4th September 2025 - 12:20 AM
