> Body sand blasting or acid dipping
r_towle
post Nov 4 2014, 07:45 AM
Custom Member
When prepping a car for sandblasting, what is the common thing to do with the aluminum tags in the front trunk and door pillar?
I suppose the second question would be do I acid dip the car or get it sandblasted?
post Sep 2 2017, 07:44 PM
914-6 GT in waiting
I've been thinking about this. the 911 chassis that we get media blasted come out ok but our metal guy still has to do a ton of work once we get them back. Cut out all the swiss cheese metal that was hidden with paint and bondo, remove a lot of the epoxy primer to do the metal work, ect.
Recently we sent out some tubs to an acid dipping co. and I'm waiting to see the results.
I know the paper heater tubes dissolve in the acid.
Here's my question. what if I replace those tubes with another one by snaking it through the openings on each end of the long. Similar to what is done with oil lines on a 6 conversion or water lines on a Suby. I know the lines will have a smaller ID than stock but they could be thin walled (no high pressure like an oil or water line) so maybe the ID is big enough. If I can get enough hot air through the tube, I wonder if a large, insulated tube is needed. Even the heat on my 4 cylinder car, without a working electric fan, is HOT in the winter and unlike my daily driver, I'm not driving my six on the coldest days of the year. I'm really just looking to stay warm on the >40 degree days.
r_towle   Body sand blasting or acid dipping   Nov 4 2014, 07:45 AM
cn2800   I very carefully drilled out the rivets for those ...   Nov 4 2014, 07:59 AM
r_towle   I very carefully drilled out the rivets for those...   Nov 4 2014, 08:11 AM
partwerks   I very carefully drilled out the rivets for thos...   Nov 8 2014, 07:29 PM
mepstein   I wouldn't acid dip. You'll never be able ...   Nov 4 2014, 08:24 AM
r_towle   I wouldn't acid dip. You'll never be able...   Nov 4 2014, 08:33 AM
rudedude   Seeing the damage done to a 356 from dapo that I a...   Nov 4 2014, 08:32 AM
stevegm   :popcorn: I researched this pretty well a while ...   Nov 4 2014, 08:36 AM
altitude411   Plastic bead media blasting is the way to go in my...   Nov 4 2014, 08:40 AM
rgalla9146   When prepping a car for sandblasting, what is the...   Nov 4 2014, 03:19 PM
rick 918-S   http://www.914world.com/bbs2/index.php?sho...=2303...   Nov 4 2014, 04:10 PM
CptTripps   [url=http://www.914world.com/bbs2/index.php?showt...   Nov 7 2014, 09:01 AM
SixerJ   [url=http://www.914world.com/bbs2/index.php?show...   Nov 8 2014, 03:25 AM
McMark   Quite possibly a stupid suggestion - why not cut ...   Nov 9 2014, 10:47 AM
balljoint   I get sand all over the dash every time I turn the...   Nov 4 2014, 04:29 PM
SixerJ   Maybe useful background info, but unfortunately do...   Nov 5 2014, 05:05 PM
r_towle   Interesting note, the initial dip is a BASE. The ...   Nov 5 2014, 05:37 PM
lsintampa   I acid dipped.... Then por-15 the entire car... ...   Nov 5 2014, 06:00 PM
Mikey914   I've used soda blasting to spot clean a few ar...   Nov 5 2014, 11:32 PM
SirAndy   Whatever you do, don't use sand to blast your ...   Nov 6 2014, 11:09 AM
lsintampa   Sand will get into everything, for sure. Ever go ...   Nov 6 2014, 11:32 AM
r_towle   My plan, either way, is to strip it to the tub and...   Nov 6 2014, 06:30 PM
Katmanken   And you can do the electrolysis process on a whole...   Nov 6 2014, 06:31 PM
Phoenix-MN   And you can do the electrolysis process on a whol...   Nov 7 2014, 07:26 AM
r_towle   I am starting to lean toward dipping the car, then...   Nov 6 2014, 06:35 PM
roblav1   I just went through this. Aircraft stripper - let...   Nov 7 2014, 12:59 AM
amfab   I just went through this. Aircraft stripper - le...   May 16 2017, 03:01 PM
boxsterfan   Take the floors out. There is rust in the seams. ...   Nov 7 2014, 04:33 PM
Jon H.   If you spray you high build primer on top of the e...   Nov 8 2014, 08:45 AM
veekry9   Redi-Strip. http://www.redi-strip.com/ https://w...   Nov 8 2014, 08:13 PM
veekry9   Come to think of it,I haven't come across anyo...   Nov 8 2014, 08:24 PM
Maltese Falcon   Had our current- build blasted with garnet sand. T...   Nov 8 2014, 09:57 PM
r_towle   So, a few years have passed. What does everyone th...   May 15 2017, 10:27 PM
bulitt   So, a few years have passed. What does everyone t...   May 16 2017, 06:58 AM
r_towle   Best/sad part of this is I was searching for any t...   May 15 2017, 10:35 PM
McMark   Blasting for me.   May 16 2017, 06:38 AM
6freak   Blasting for me. with ice! look into that...   May 16 2017, 02:20 PM
Perry Kiehl   If you have a really rusty shell, then dip it, but...   May 16 2017, 10:16 AM
rgalla9146   If you have a really rusty shell, then dip it, bu...   May 16 2017, 12:43 PM
jimkelly   the question i have about acid dip is that all pai...   May 16 2017, 06:24 PM
Tdskip   the question i have about acid dip is that all pa...   Mar 23 2021, 03:52 PM
bulitt   Rich: talk to Scotty. He has the dustless set up a...   May 17 2017, 07:40 AM
mepstein   Rich: talk to Scotty. He has the dustless set up ...   May 17 2017, 07:57 AM
r_towle   I am not doing this project, I will sub contract i...   May 17 2017, 08:07 AM
cary   On Doug's project we went with soda blasting, ...   May 17 2017, 08:20 AM
roblav1   My old car is the white one in the rotisserie. I...   Sep 2 2017, 06:21 PM
mepstein   I've been thinking about this. the 911 chassis...   Sep 2 2017, 07:44 PM
CptTripps   ::: digging up an old topic, so I don't have t...   Mar 23 2021, 09:37 AM
ClayPerrine   ::: digging up an old topic, so I don't have ...   Mar 23 2021, 09:47 AM
Root_Werks   :agree: If you want to dip, prepare the body for...   Mar 23 2021, 10:02 AM
mepstein   Plastic media blasting worked well for us when I w...   Mar 23 2021, 10:07 AM
worn   Plastic media blasting worked well for us when I ...   Mar 23 2021, 03:46 PM
Cairo94507   I would do media blasting and ask the blaster what...   Mar 23 2021, 04:22 PM
Tdskip   I would do media blasting and ask the blaster wha...   Mar 23 2021, 05:09 PM
ClayPerrine   I would do media blasting and ask the blaster wh...   Mar 23 2021, 08:25 PM
Luke M   This thread came up at the right time. I just met ...   Mar 24 2021, 05:04 AM
Cairo94507   I agree re the dry ice blasting, but I think that ...   Mar 24 2021, 07:30 AM
930cabman   I would not dip, there are too many hollow section...   Mar 24 2021, 07:46 AM
mate914   I used baking soda mixed with aluminum oxide on ni...   Mar 24 2021, 09:36 AM
PanelBilly   I used some plumbing plugs to seal off the heater ...   Mar 24 2021, 01:24 PM
914werke   Both media blasted (dry) and soda blasted (wet) a ...   Mar 24 2021, 05:01 PM
racerbvd   Back when you could reasonably get a tub acid dipp...   Mar 24 2021, 05:17 PM
GeorgeKopf   I'm going to acid dip my 1974 chassis. I foun...   Mar 24 2021, 06:10 PM
gandalf_025   This is what my car looked like when it came back ...   Mar 25 2021, 12:02 PM
930cabman   This is what my car looked like when it came back...   Mar 25 2021, 12:53 PM
d914   I did soda on my car.. worked well.. Just needs a ...   Mar 25 2021, 12:10 PM
gandalf_025   Car looks more like this now.. It was painted imme...   Mar 25 2021, 01:09 PM
mepstein   Car looks more like this now.. It was painted imm...   Mar 25 2021, 03:33 PM
gandalf_025   I wasn’t involved in the blasting process. The b...   Mar 25 2021, 04:02 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:50 AM
