| capitolatim |
Sep 4 2017, 07:39 PM
Member ![]() ![]() Group: Members Posts: 64 Joined: 11-June 15 From: capitola,ca Member No.: 18,841 Region Association: Northern California |
I can not get my shifter properly adjusted, it's a side shift. sloppy intp 1st gear and absolutely can not get into fourth.
I've read several posts but can't make it work. It was working fine before I did an engine rebuild. Any videos, etc? Cheers Tim in Capitola, CA |
| Amphicar770 |
Sep 5 2017, 01:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
Took me a while but not hard once you get the hang of it. Once you get close, make some alignment marks on shaft and coupling. Small Adjustment in either direction can make a big difference so it is helpful to have reference mark.
You.mentioned engine rebuild. Make sure clutch is properly adjusted. |
capitolatim How to adjust shift linkage Sep 4 2017, 07:39 PM
second wind
I can not get my shifter properly adjusted, it... Sep 4 2017, 08:02 PM
capitolatim
I can not get my shifter properly adjusted, it... Sep 5 2017, 10:24 AM
Elliot Cannon This might help. http://www.pelicanparts.com/te... Sep 4 2017, 08:31 PM
Keith914 If side shift, remove black plastic oval cover at ... Sep 5 2017, 03:56 PM
capitolatim Thanks, will try all the suggestions, don't li... Sep 5 2017, 04:17 PM
DM_2000 Something to be aware of when adjusting any linkag... Sep 5 2017, 06:49 PM
ClayPerrine Try this procedure:
How to adjust your side shift... Sep 8 2017, 09:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 12:30 PM |
