LED light question |
haasman |
Sep 24 2017, 09:34 PM
Newbie Group: Members Posts: 30 Joined: 19-January 09 From: United States Member No.: 9,947 Region Association: Northern California |
Installed LED bulbs in my 70 914-6. Really like their brightness. Especially these days when drivers tend to brake only after seeing a third high mounted brake light of modern cars.
I installed yellow LEDs for the rear turn signals and when operating, yellow comes through the red taillight lenses! Unexpected surprise. Used red LED for the brake lights and wow, do they pop. My question- in the front after installing yellow LED bulbs, when using a right turn-signal the left bulb also glows, though not as bright. Left turn signal works great and the right one doesn't indicate anything. With 4-way hazard lights, all operate properly. I systematically checked the grounds at each light housing. Any ideas/suggestions? Haasman |
rothaus |
Sep 25 2017, 02:55 AM
Member Group: Members Posts: 119 Joined: 20-November 10 From: Virginia Member No.: 12,404 Region Association: None |
Installed LED bulbs in my 70 914-6. Really like their brightness. Especially these days when drivers tend to brake only after seeing a third high mounted brake light of modern cars. I installed yellow LEDs for the rear turn signals and when operating, yellow comes through the red taillight lenses! Unexpected surprise. Used red LED for the brake lights and wow, do they pop. My question- in the front after installing yellow LED bulbs, when using a right turn-signal the left bulb also glows, though not as bright. Left turn signal works great and the right one doesn't indicate anything. With 4-way hazard lights, all operate properly. I systematically checked the grounds at each light housing. Any ideas/suggestions? Haasman Did you check if it does the same with the old bulbs, on the front turning signal ? Cheers Engelbert |
Lo-Fi Version | Time is now: 9th June 2024 - 11:52 PM |
