LED light question |
haasman |
Sep 24 2017, 09:34 PM
Newbie Group: Members Posts: 30 Joined: 19-January 09 From: United States Member No.: 9,947 Region Association: Northern California |
Installed LED bulbs in my 70 914-6. Really like their brightness. Especially these days when drivers tend to brake only after seeing a third high mounted brake light of modern cars.
I installed yellow LEDs for the rear turn signals and when operating, yellow comes through the red taillight lenses! Unexpected surprise. Used red LED for the brake lights and wow, do they pop. My question- in the front after installing yellow LED bulbs, when using a right turn-signal the left bulb also glows, though not as bright. Left turn signal works great and the right one doesn't indicate anything. With 4-way hazard lights, all operate properly. I systematically checked the grounds at each light housing. Any ideas/suggestions? Haasman |
Olympic 914 |
Sep 25 2017, 05:42 AM
Group: Members Posts: 1,673 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I had the same problem when I installed my LED lights. I was getting a "ghost" flash on both sides.
you make a Y piece and install it as shown here. > http://www.914world.com/bbs2/index.php?sho...=272915&hl= That should solve your problem. |
haasman |
Sep 25 2017, 10:21 AM
Thank you for this solution. Will check it out this weekend.
I had the same problem when I installed my LED lights. I was getting a "ghost" flash on both sides. you make a Y piece and install it as shown here. > http://www.914world.com/bbs2/index.php?sho...=272915&hl= That should solve your problem. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:07 AM |
