Wheel Spacers |
Wheel Spacers |
cal914 |
Sep 24 2017, 12:04 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
I want to put 25mm [1"] spacers on my front wheels of my GT conversion to bring the wheels out a bit further,if i were to put these on what if any problems could this cause to the car
Thanks Brian |
drifter914 |
Sep 24 2017, 05:53 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Four lug or five ? If you have a 5-stud conversion, you can use longer studs in the rotors & 1" slip over spacers. Not sure of supplier of spacers, but T3 Technique in Redmond, Wa has amazing supplies of wheel studs, bolts. 425.836.5983.
Best wishes... Terry |
porschetub |
Sep 25 2017, 02:45 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Four lug or five ? If you have a 5-stud conversion, you can use longer studs in the rotors & 1" slip over spacers. Not sure of supplier of spacers, but T3 Technique in Redmond, Wa has amazing supplies of wheel studs, bolts. 425.836.5983. Best wishes... Terry As an engineer the concept of studs that long concerns me,but that just me,I know people on here have done it and Porsche did it on the early 944 with the spacer they used in the rear of those cars. The 30mm H&R one I showed is actually a spacer adaptor,I prefer this type of design for the thicker spacers. |
Lo-Fi Version | Time is now: 13th June 2024 - 12:46 AM |
