LCOX |
Member ![]() ![]() Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None ![]() |
I noticed that the factory oil pressure switch was leaking on my 914. I removed it but the previous owner put it in crooked and stripped the threads in the case that the switch threads into. Can this be repaired with engine in car? What size drill, tap and insert do I need or is there another way to fix it? Thanx L
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 684 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
It's rather risky, but this can be fixed in the car. The technique is to get the proper tap and coat the tap heavily with a thick, sticky grease. Then, turn in the tap until it starts to cut threads and go about 1/2 to 1 turn more, remove the tap, clean the chips and grease off, re-grease the tap and repeat until you go in deep enough to create sufficient new threads. Two full turns should be sufficient.
The idea is that the chips should stick to the grease on the tap and not fall into the engine. I've done it on horizontal holes and it worked okay. I haven't tried it on any vertical-down holes. The risk is that metal chips can fall into your oil passages, which would be not good. If it were me, I would be thinking about removing the engine, draining the oil, mounting it on an engine stand and rolling the engine upside-down. That way, any chips that don't stick to the grease should theoretically fall down out of the hole, instead of into the engine. One other option, which is somewhat safer but potentially more difficult is to use a die to make the tapered thread on the switch deeper. I would actually recommend doing it to a brass fitting rather than the actual switch (and screw the switch into the fitting), just in case you mess it up. But, this only works if there are still good threads deeper in the hole in the block. If not, you'll have to re-tap the hole in the block. |
Lo-Fi Version | Time is now: 3rd September 2025 - 07:24 AM |
