> oil pressure switch stripped need advice
LCOX
post Sep 29 2017, 01:49 PM
I noticed that the factory oil pressure switch was leaking on my 914. I removed it but the previous owner put it in crooked and stripped the threads in the case that the switch threads into. Can this be repaired with engine in car? What size drill, tap and insert do I need or is there another way to fix it? Thanx L
DM_2000
post Sep 30 2017, 07:18 AM
Even with teflon tape there will usually be some metal to metal contact. If there isn't a hose clamp +a ground wire will fix things. Or put a short compression spring around the threads / under the switch.
The "right" way to fix this is to strip the motor bare and helicoil, but that gets to be $$$.
BillC
post Sep 30 2017, 07:36 AM
I googled it -- turns out you can use helicoils to fix NPT holes. Did not know that.
http://www.stanleyengineeredfastening.com/..._HC903-rev4.pdf
But, since it requires drilling and tapping, it's not something you can do with the engine in place.
- Lo-Fi Version Time is now: 3rd September 2025 - 07:24 AM
