porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,919 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Based on what I have studied I seem to think this is not right,new pressure plate/disk,new cable,rebuilt pedal assembly etc ,etc and unknown flywheel in good condition,thinking it has been heavily machined,pedal adjustment is by the book...my idea is the lever is hitting the trans case when pedal fully down...help please before I pull the g/box again.
![]() TIA guys. P.S.clutch cable tube is fine. |
porschetub |
Mongreled a thin wall cheapo $1 socket ,bored it out with 14mm drill to get clearance over the ball on the pivot,worked a treat.
![]() When I removed the pivot I noticed a strong smell of gearoil,appears the mounting hole is a steel threaded insert going into the case but open ended. PET shows a washer underneath of 8mm x 4mm...not what I found,more like 1.5 thick so added another washer 1.5mm as the one I found. Resealed and put it back in fingers crossed for a result. ![]() More to follow (IMG:style_emoticons/default/beer.gif) . |
Lo-Fi Version | Time is now: 3rd September 2025 - 11:45 PM |
