> Clutch arm position ?, correct or not...
porschetub
post Oct 1 2017, 04:55 PM
Based on what I have studied I seem to think this is not right,new pressure plate/disk,new cable,rebuilt pedal assembly etc ,etc and unknown flywheel in good condition,thinking it has been heavily machined,pedal adjustment is by the book...my idea is the lever is hitting the trans case when pedal fully down...help please before I pull the g/box again.
TIA guys.
P.S.clutch cable tube is fine.
r_towle
post Oct 3 2017, 10:17 PM
Custom Member
Measure the flywheel to see how much was ground off.
Spec is here somewhere in a diagram. Search for flywheel, should be easy to find.
Adding two washers is not unheard of. After two it's time for a new flywheel.
porschetub   Clutch arm position ?   Oct 1 2017, 04:55 PM
mobymutt   Mine was doing the same thing -- I adjusted the cl...   Oct 1 2017, 05:19 PM
ndfrigi   Mine was doing the same thing -- I adjusted the c...   Oct 1 2017, 05:44 PM
Larmo63   I think he meant the silver nut at the edge of the...   Oct 1 2017, 05:59 PM
mobymutt   I did, but I suspect it's just the back end of...   Oct 1 2017, 06:31 PM
r_towle   You can shim the clutch release fork pivot ball to...   Oct 1 2017, 06:37 PM
porschetub   You can shim the clutch release fork pivot ball t...   Oct 1 2017, 09:00 PM
ndfrigi   You can shim the clutch release fork pivot ball ...   Oct 1 2017, 09:24 PM
porschetub   [quote name='porschetub' post='2533397' date='Oct...   Oct 1 2017, 10:01 PM
rhodyguy   Put some washers under the cable nut. If that...   Oct 1 2017, 09:31 PM
mgphoto   Adding washers or extending anything to compensate...   Oct 2 2017, 03:53 PM
porschetub   Adding washers or extending anything to compensat...   Oct 2 2017, 05:31 PM
r_towle   Cut a board to fit sideways in front of the seat t...   Oct 2 2017, 06:24 PM
porschetub   Cut a board to fit sideways in front of the seat ...   Oct 2 2017, 10:37 PM
Lucky9146   [quote name='r_towle' post='2533670' date='Oct 3 ...   Oct 2 2017, 11:03 PM
porschetub   [quote name='r_towle' post='2533670' date='Oct 3...   Oct 3 2017, 12:01 PM
mark04usa   Clearance is an issue. I use a 1/4" drive dee...   Oct 2 2017, 11:07 PM
porschetub   Mongreled a thin wall cheapo $1 socket ,bored...   Oct 3 2017, 06:03 PM
r_towle   Measure the flywheel to see how much was ground of...   Oct 3 2017, 10:17 PM
porschetub   Measure the flywheel to see how much was ground o...   Oct 4 2017, 03:45 AM
Dr Evil   Im at work so don't have diagram here, unfortu...   Oct 4 2017, 11:01 AM
porschetub   Im at work so don't have diagram here, unfort...   Oct 4 2017, 12:41 PM
johnhora   here you go...flywheel specs   Oct 4 2017, 02:44 PM
Dave_Darling   here you go...flywheel specs Notice the upper-r...   Oct 6 2017, 02:34 PM
porschetub   here you go...flywheel specs Notice the upper-...   Oct 7 2017, 01:17 PM
Dr Evil   Rock on! I just got home....so no need to do t...   Oct 4 2017, 03:39 PM
porschetub   Thanks guys ,getting ready to refit box,will pull ...   Oct 4 2017, 03:51 PM
porschetub   Ok got the clutch out,all in order,my digital vern...   Oct 4 2017, 04:08 PM
johnhora   porschetub... also check the fork....there is a l...   Oct 4 2017, 07:03 PM
porschetub   porschetub... also check the fork....there is a ...   Oct 4 2017, 11:30 PM
r_towle   Broken spring in pressure plate is hard to test. S...   Oct 5 2017, 04:01 PM
porschetub   Broken spring in pressure plate is hard to test. ...   Oct 6 2017, 01:45 AM
- Lo-Fi Version Time is now: 3rd September 2025 - 11:46 PM
