Bed liner in the cabin? |
mb911 |
Oct 16 2017, 01:39 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I really want to spray a bed liner inside the cabin but don't want anything that won't set up hard.. I plan to epoxy prime then bed liner og sorts then color.. Any suggestions? I don't want it to smell in the end.. Any thoughts?
DM_2000 |
Oct 16 2017, 06:05 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
Bed liner spray is heavy and lumpy. I'd expect it to be difficult to keep clean since you really won't want to hose the car out.
As for spraying the under side of the car why bother unless they plan on driving in the snow / salt. Even then, bodies generally don't rust in the middle of a panel, rust usually starts at a seam since there is a sharp edge that becomes difficult to seal. My car has black epoxy ( PPG DP-- LF ) interior door sills / shifter tunnel and gray floors, it works just fine. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:59 AM |
