Bed liner in the cabin? |
mb911 |
Oct 16 2017, 01:39 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I really want to spray a bed liner inside the cabin but don't want anything that won't set up hard.. I plan to epoxy prime then bed liner og sorts then color.. Any suggestions? I don't want it to smell in the end.. Any thoughts?
mb911 |
Oct 16 2017, 07:55 PM
Ok so some research and looks like monsta liner is what I saw.. Great stuff. I was thinking it would be great for an extra layer of sound deadening and durability.. I will definitely be doing this on the underside becuase I plan to drive the car .. It will help with rock chips from rocks thrown up inside the fenders..
Probably just spray epoxy primer and paint the inside.. |
Rand |
Oct 16 2017, 07:57 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Ok so some research and looks like monsta liner is what I saw.. Great stuff. I was thinking it would be great for an extra layer of sound deadening and durability.. I will definitely be doing this on the underside becuase I plan to drive the car .. It will help with rock chips from rocks thrown up inside the fenders.. Probably just spray epoxy primer and paint the inside.. Do you wonder if there should be different treatments underside vs inside? |
mb911 |
Oct 16 2017, 08:17 PM
Ok so some research and looks like monsta liner is what I saw.. Great stuff. I was thinking it would be great for an extra layer of sound deadening and durability.. I will definitely be doing this on the underside becuase I plan to drive the car .. It will help with rock chips from rocks thrown up inside the fenders.. Probably just spray epoxy primer and paint the inside.. Do you wonder if there should be different treatments underside vs inside? Not sure what you mean?? I want to protect the wheel wells from dings from the inside cracking the paint on the topside of the fender. This also creates a good moisture barrier beyond the epoxy primer.. Thus wheel wells is my main concern.. Thought about it on bottom of the floorpan mostly becuase of sound and consistency with wheel wells.. Now inside thw cabin was just a thought.. .. Thinking outloud I guess.. I am only weeks away from epoxy priming so doing some research. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:18 PM |
