gas pedal stop, Just a semi hollow plastic bolt? |
Calwaterbear |
Oct 21 2017, 11:57 AM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
rebulding my pedal board, have one original that worked OK as a template, but the stop had some guys rig using a long bolt, nuts and washers etc. In the other example I have the board is completely destroyed, but I was able to extract a plastic boltt from the stop fitting.
In looking at the Haynes Manual, itr appears as this is the original (stock) piece. is that correct? and does it just screw into the nut on the plate - no other hardware? thanks |
GeorgeRud |
Oct 21 2017, 12:47 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
It’s justaplastic bolt with no locknut. Used to stop the throttle at the full open position, so it’s adjustable.
Calwaterbear |
Oct 21 2017, 03:43 PM
Lo-Fi Version | Time is now: 8th June 2024 - 05:18 PM |
