| rgolia |
Oct 23 2017, 09:51 AM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
| VaccaRabite |
Oct 24 2017, 12:15 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
About the dual senders.
I don't like them. They trip the oil Idiot light much earlier then the stock sender. Some people don't mind that, but on some engines you can get the oil light on at hot idle but the oil pressure is still within spec. Disconcerting. I ran my hose to a T fitting, and have the pressure sender on one side and the stock idiot light sender on the other. Zach |
| Mark Henry |
Oct 24 2017, 02:56 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
About the dual senders. I don't like them. They trip the oil Idiot light much earlier then the stock sender. Some people don't mind that, but on some engines you can get the oil light on at hot idle but the oil pressure is still within spec. Disconcerting. I ran my hose to a T fitting, and have the pressure sender on one side and the stock idiot light sender on the other. Zach (IMG:style_emoticons/default/agree.gif) nothing beats the factory oil light switch. To me if you're really worried about oil pressure a big red light hooked to the idiot light is you best bet. |
rgolia Oil Pressure sender hose blew out Oct 23 2017, 09:51 AM
Keith914 Buy a 928 SS braided brake line (Bruce Stone's... Oct 23 2017, 10:06 AM
bdstone914
Buy a 928 SS braided brake line (Bruce Stone... Oct 24 2017, 08:20 AM
GregAmy To clarify...if it was the hose that failed, why d... Oct 23 2017, 10:40 AM
cuddyk Check this out. Great kit.
http://www.42draftdes... Oct 23 2017, 10:41 AM
NeunEinVier
http://www.42draftde... Oct 31 2017, 11:04 AM
era vulgaris
So last night the hose from the engine to the oil... Oct 24 2017, 08:14 AM
GregAmy
I don't like them. ... Oct 24 2017, 02:59 PM
malcolm2
I don't like them. T... Nov 13 2017, 01:14 PM
rgolia Thanks all. I spoke with Chris at Tangerine and h... Oct 24 2017, 02:33 PM
DM_2000
Thanks all. I spoke with Chris at Tangerine and ... Oct 24 2017, 04:43 PM
cuddyk The kit I linked above has 3 available ports so yo... Oct 24 2017, 04:15 PM
rgolia Took the strainer out....no metal frags to speak o... Oct 26 2017, 10:03 AM
'73-914kid I would cut open your oil filter that was on the c... Oct 26 2017, 11:32 AM
DM_2000 Motor is probably OK unless it was in poor shape p... Oct 26 2017, 05:22 PM
Porschef Ralph, hope all is ok, were you using a grease gun... Oct 26 2017, 06:45 PM
rgolia Not sure of the origin of the hose, most likely ca... Oct 27 2017, 09:57 AM
rgolia Got oil back in it and fired it up. After a short... Oct 31 2017, 09:46 AM
DM_2000
Got oil back in it and fired it up. After a shor... Oct 31 2017, 05:00 PM
GregAmy - Put suspect numbers-matching engine in the basem... Oct 31 2017, 10:16 AM
McMark
- Put suspect numbers-matching engine in the base... Oct 31 2017, 10:23 AM
Dave_Darling Adjust the valves before you do your road test. I... Oct 31 2017, 11:03 AM
rgolia Fired it up this weekend and let it run for 15-20 ... Nov 6 2017, 03:03 PM
rgolia Well gave it a good warm up and then hit the road.... Nov 13 2017, 10:59 AM
McMark A quick refresh isn't outside your skill set. ... Nov 13 2017, 12:53 PM
pete000 Here is the kit I got from a Miata MX5 performance... Nov 13 2017, 01:05 PM
Dave_Darling
Here is the kit I got from a Miata MX5 performanc... Nov 13 2017, 02:45 PM
pete000
Here is the kit I got from a Miata MX5 performan... Nov 13 2017, 04:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:09 PM |
