> Oil Pressure sender hose blew out, need help
rgolia
post Oct 23 2017, 09:51 AM
GeoJoe
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
rgolia
post Oct 26 2017, 10:03 AM
GeoJoe
Took the strainer out....no metal frags to speak of...some small copper specks but smaller than the screen, so maybe good news. There was about 1/2 quart of oil plus the filter, so probably bad news. Plan is to try the restart tomorrow or Saturday. Any advice or thoughts on how to proceed or what to expect are appreciated. (IMG:style_emoticons/default/sad.gif)
rgolia   Oil Pressure sender hose blew out   Oct 23 2017, 09:51 AM
Keith914   Buy a 928 SS braided brake line (Bruce Stone's...   Oct 23 2017, 10:06 AM
bdstone914   Buy a 928 SS braided brake line (Bruce Stone...   Oct 24 2017, 08:20 AM
GregAmy   To clarify...if it was the hose that failed, why d...   Oct 23 2017, 10:40 AM
cuddyk   Check this out. Great kit. http://www.42draftdes...   Oct 23 2017, 10:41 AM
NeunEinVier   Check this out. Great kit. http://www.42draftde...   Oct 31 2017, 11:04 AM
era vulgaris   So last night the hose from the engine to the oil...   Oct 24 2017, 08:14 AM
Vacca Rabite   About the dual senders. I don't like them. Th...   Oct 24 2017, 12:15 PM
Mark Henry   About the dual senders. I don't like them. T...   Oct 24 2017, 02:56 PM
GregAmy   About the dual senders. I don't like them. ...   Oct 24 2017, 02:59 PM
malcolm2   About the dual senders. I don't like them. T...   Nov 13 2017, 01:14 PM
rgolia   Thanks all. I spoke with Chris at Tangerine and h...   Oct 24 2017, 02:33 PM
DM_2000   Thanks all. I spoke with Chris at Tangerine and ...   Oct 24 2017, 04:43 PM
cuddyk   The kit I linked above has 3 available ports so yo...   Oct 24 2017, 04:15 PM
rgolia   Took the strainer out....no metal frags to speak o...   Oct 26 2017, 10:03 AM
'73-914kid   I would cut open your oil filter that was on the c...   Oct 26 2017, 11:32 AM
DM_2000   Motor is probably OK unless it was in poor shape p...   Oct 26 2017, 05:22 PM
Porschef   Ralph, hope all is ok, were you using a grease gun...   Oct 26 2017, 06:45 PM
rgolia   Not sure of the origin of the hose, most likely ca...   Oct 27 2017, 09:57 AM
rgolia   Got oil back in it and fired it up. After a short...   Oct 31 2017, 09:46 AM
DM_2000   Got oil back in it and fired it up. After a shor...   Oct 31 2017, 05:00 PM
GregAmy   - Put suspect numbers-matching engine in the basem...   Oct 31 2017, 10:16 AM
McMark   - Put suspect numbers-matching engine in the base...   Oct 31 2017, 10:23 AM
Dave_Darling   Adjust the valves before you do your road test. I...   Oct 31 2017, 11:03 AM
rgolia   Fired it up this weekend and let it run for 15-20 ...   Nov 6 2017, 03:03 PM
rgolia   Well gave it a good warm up and then hit the road....   Nov 13 2017, 10:59 AM
McMark   A quick refresh isn't outside your skill set. ...   Nov 13 2017, 12:53 PM
pete000   Here is the kit I got from a Miata MX5 performance...   Nov 13 2017, 01:05 PM
Dave_Darling   Here is the kit I got from a Miata MX5 performanc...   Nov 13 2017, 02:45 PM
pete000   Here is the kit I got from a Miata MX5 performan...   Nov 13 2017, 04:21 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:04 PM
