> L-Jet Auxillary Air Regulator or Valve?, Proper operation of the AAR
malcolm2
post Oct 17 2017, 12:38 PM
I found an very old, very short post about the subject and cleaning the AAR with PB Blaster. So I guess I'll try that. But that post did not answer my current problem.
I have had my AAR off of my car and the hose connections plugged for about 6 months now. But it is getting cold and it has been recommended that I put it back in service. So I tested it. And took some pictures along the way. I did the FREEZER test and it opened.
I sat it in the sun. Very warm exterior case. Kinda tuff to hold it. It absorbed a good bit of heat.... and almost closed.
Then I broke out my handy dandy 12v drill battery and within a few seconds it was closed.
here is the question..... I tried to blow thru the closed hole and had ZERO problem doing that. So I suppose when closed that NO AIR should pass thru, correct? Will the PB Blaster cleaning help, or is this baby done for? Any ideas on fixing?
Thanks.
ClayPerrine
post Oct 26 2017, 12:36 PM
It is not designed to be closed completely. There is still a small amount of airflow through the AAR even after it is closed.
Just the way it was designed.
malcolm2   L-Jet Auxillary Air Regulator or Valve?   Oct 17 2017, 12:38 PM
timothy_nd28   If you can blow thru the AAR after it fully closed...   Oct 17 2017, 01:37 PM
malcolm2   I remember that you suggested a BRAND new one.....   Oct 17 2017, 03:30 PM
jim_hoyland   The force of blowing air through the AAR far excee...   Oct 17 2017, 04:31 PM
pete000   The force of blowing air through the AAR far exce...   Oct 17 2017, 06:58 PM
echocanyons   I think new ones are only a available for a small ...   Oct 17 2017, 06:58 PM
pete000   I think new ones are only a available for a small...   Oct 17 2017, 07:04 PM
Dave_Darling   I believe that early 944 ones can be adapted to wo...   Oct 17 2017, 08:18 PM
porschetub   I believe that early 944 ones can be adapted to w...   Oct 18 2017, 04:29 PM
ClayPerrine   Aux Air Regulator for sale at Bus Depot $1...   Oct 18 2017, 04:35 PM
malcolm2   Aux Air Regulator for sale at Bus Depot ...   Oct 18 2017, 07:19 PM
Philip W.   I have one of those that I bought a long time ago ...   Oct 19 2017, 08:10 AM
malcolm2   I have one of those that I bought a long time ago...   Oct 19 2017, 10:47 AM
Philip W.   I have one of those that I bought a long time ag...   Oct 26 2017, 10:52 AM
ClayPerrine   It is not designed to be closed completely. There ...   Oct 26 2017, 12:36 PM
malcolm2   It is not designed to be closed completely. There...   Oct 30 2017, 07:54 AM
ndfrigi   Like Jim and Clay said, same when i still have my ...   Oct 26 2017, 01:58 PM
Philip W.   :beer2: awesome! let us know how it car runs ...   Oct 30 2017, 08:03 AM
malcolm2   :beer2: awesome! let us know how it car runs...   Nov 13 2017, 09:57 AM
timothy_nd28   Since your AAV is now functioning correctly, I wou...   Nov 13 2017, 04:45 PM
- Lo-Fi Version Time is now: 23rd September 2026 - 02:36 PM
