| Robnxious |
Sep 10 2017, 02:41 PM
RobnxiousOne ![]() ![]() Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Yes, I know they will fit on a narrow body, that's not my question. My question is, if you have gone to the lower profile tire, how did you like it? How much does this lower the car as well, since I already scrap coming out the driveway, and just now went and bought one of those Bridjit curb ramps. I plan on also adding Mark's fiberglass airdam on it too. So basically my questions are
1) I know you get better handling due to less tire sway, but how is the ride compared to a higher profile tire? I have never driven on low profiles, and think they would look and perform nicely, but haven't heard (or remember reading) about people who have the lower profile tires. I think the 195s are the biggest I can fit in there from what I have seen, and I sort of like the narrow body look. 2) Will they make the car so low that clearance is a major issue? Does no good to lower the go kart down further if I can't get over one of Sacramento's MANY speed bumps Thanks |
| Dave_Darling |
Sep 10 2017, 11:53 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I used to run 195/50-15s. I liked them at the time. Eventually, I liked them less.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-121-1505109211.1.jpg) I had originally used 195/60-15 in the same make and model, and found several differences when I went to 50-series tires: - Lower gearing for better acceleration out of corners - Stiffer sidewalls resulting in (slightly) more grip - Better feedback from the tires - Harder ride due to shorter sidewalls - Freeway speeds required ~500 RPM more - On a few autoX courses I had to shift up to 3rd and back, costing me some time When I went to 50-series tires, I was finally able to feel the car well enough to catch a slide before it evolved into a spin. I had never done that on the 60-series tires. Eventually, having to run higher RPMs on the freeway did get to me. The type of tires I wanted to run were also becoming harder to find in 195/50, so I wound up going with 205/60-15s. --DD |
| Guberif |
Oct 27 2017, 04:04 PM
Newbie ![]() Group: Members Posts: 33 Joined: 27-July 16 From: Washington Member No.: 20,227 Region Association: Pacific Northwest |
I used to run 195/50-15s. I liked them at the time. Eventually, I liked them less. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-121-1505109211.1.jpg) I had originally used 195/60-15 in the same make and model, and found several differences when I went to 50-series tires: - Lower gearing for better acceleration out of corners - Stiffer sidewalls resulting in (slightly) more grip - Better feedback from the tires - Harder ride due to shorter sidewalls - Freeway speeds required ~500 RPM more - On a few autoX courses I had to shift up to 3rd and back, costing me some time When I went to 50-series tires, I was finally able to feel the car well enough to catch a slide before it evolved into a spin. I had never done that on the 60-series tires. Eventually, having to run higher RPMs on the freeway did get to me. The type of tires I wanted to run were also becoming harder to find in 195/50, so I wound up going with 205/60-15s. --DD Hey Darling Dave, I totally agree with you I love the 195/50ZR/15 (made by Yokohama - nla for the A-008 type)which I need to replace, can't even find any ZR rated tires anymore. I've talked to you a couple of times on the phone years & years ago and you've always had Rock Solid advice. So, here's my question. I deffinately want to stay with the low pro's no debating that one - your dead right world of difference! But I would like to have more accurate speedo & I wouldnt mind having lower rpm's. Where the 'Rub' is (forgive the pun) that my tires I have on my chrome rims are 185/65/15. the drivers rear clearance is super tight, can't even get my pinkie in between tire and well. do you know if these chrome rims are totally offset? or are they the same as the Fuch's? (I'll upload pic of the chrome ones) I will be putting the new tires on my 2.0 L. OEM Fuch's .....so, If I were to go a little bigger with still a 50% would that work? Could you suggest any sizes to check out? Sorry to ask this, there is no tire shop nearby so I will be having to order over the internet, so I cant just go down to a shop or anything of the sort, that and like I said - great advice before - thanks. Bonnie ![]() |
| euro911 |
Oct 28 2017, 10:09 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,951 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Hey Darling Dave, I totally agree with you I love the 195/50ZR/15 (made by Yokohama - nla for the A-008 type)which I need to replace, can't even find any ZR rated tires anymore. I've talked to you a couple of times on the phone years & years ago and you've always had Rock Solid advice. So, here's my question. I deffinately want to stay with the low pro's no debating that one - your dead right world of difference! But I would like to have more accurate speedo & I wouldnt mind having lower rpm's. Where the 'Rub' is (forgive the pun) that my tires I have on my chrome rims are 185/65/15. the drivers rear clearance is super tight, can't even get my pinkie in between tire and well. do you know if these chrome rims are totally offset? or are they the same as the Fuch's? (I'll upload pic of the chrome ones) I will be putting the new tires on my 2.0 L. OEM Fuch's .....so, If I were to go a little bigger with still a 50% would that work? Could you suggest any sizes to check out? Sorry to ask this, there is no tire shop nearby so I will be having to order over the internet, so I cant just go down to a shop or anything of the sort, that and like I said - great advice before - thanks. Bonnie ![]() Bonnie, some 914s came out of the factory with non-symmetrical rear suspension too. The rear track is wider than the front to begin with, so fitting wider wheels is sort of iffy, especially if the offset/backspacing of the wheels isn't correct for the car. I installed a nice set of 5.5" EMPI 8-spoke freshly powder-coated wheels with Falken 195/65-15 tires on the '71, but the left rear rubbed the fender lip (IMG:style_emoticons/default/dry.gif) ... The backspacing on those wheels was for VW Bugs/Ghias/Squrebacks, etc. - so I sold them. I stated this issue in my for sale ad, and they fit just fine on the gentleman's car who purchased them. I doubt you'll have any issues with the (real) factory 4-lug Fuchs wheels though, they have the correct backspacing. Typically, 195/65's on those will present no issues, and a lot of folks do run with 205/60s with no issues either. In any event, you can install your 'un-tired' wheels on the rear and measure the distance to the fender lip about 2~3" above the outer rim of the wheels (where the tire will be wider than the wheel itself) to see how much clearance you'll have. Caution, though, some manufacturer's tires are a tad wider, even if listed as the same size. |
Robnxious Yet another tire question Sep 10 2017, 02:41 PM
arne Overall diameter of a 195/55 is about 23.4", ... Sep 10 2017, 02:52 PM
Robnxious
Overall diameter of a 195/55 is about 23.4",... Sep 10 2017, 03:29 PM
mepstein 205x60 fit most cars with 2.0 Fuchs so there's... Sep 10 2017, 03:12 PM
Robnxious
205x60 fit most cars with 2.0 Fuchs so there... Sep 10 2017, 03:26 PM
Olympic 914
I have the Dan Gurney Western Wheels on it right... Sep 12 2017, 07:50 AM
Mark Henry I think the low profile tires on a 15" wheel ... Sep 10 2017, 03:46 PM
arne It may be just me, I'm not a fan of low pro ti... Sep 10 2017, 03:46 PM
arne I agree that the Fuchs don't look great with t... Sep 10 2017, 03:55 PM
Robnxious All right, I will yield to more learned minds than... Sep 10 2017, 05:00 PM
Coondog Here's what my 205-55-15 tire look like
Sep 10 2017, 06:36 PM
steuspeed I am running Dunlop Direzza Star Spec 195-55-15 ti... Sep 10 2017, 06:36 PM
GeorgeRud I'm running Michelin Exalto 195-65/15s on my 1... Sep 10 2017, 06:58 PM
Dave_Darling .... I would like to have more accurate speedo ... Oct 27 2017, 11:18 PM
BK911 195.60.15
I like them.
Sep 11 2017, 06:27 AM
Philip W. ive run 4 diifferent rims and tire set ups on my c... Sep 11 2017, 08:41 AM
Philip W. current look front Sep 11 2017, 08:50 AM
Racer imho, a 195/60-15 is the right tire for a -4. Ran ... Sep 11 2017, 03:41 PM
JamesM Are you running on stock rims? I think anything o... Sep 12 2017, 03:33 PM
Hans Jan 205/40/16 is the size on my tires.
The overall dia... Sep 12 2017, 08:39 PM
Philip W.
The overall di... Sep 12 2017, 08:54 PM
pvollma
And (of course) my speedo is way-off.
You can c... Sep 13 2017, 10:43 AM
euro911 I run with 195/65-15s on the 'BB' (2.1L) .... Sep 13 2017, 12:49 AM
ThreeV8s Slightly off-topic, but is everyone replacing thei... Sep 13 2017, 09:38 AM
Slightly off-topic, but is everyone replacing the... Sep 13 2017, 10:30 AM
ThreeV8s
It wont make any difference on the front. I dont ... Sep 13 2017, 11:16 AM
GregAmy Reading thread with interest...street car needs ne... Sep 13 2017, 12:00 PM
Robnxious This weekend, I'll be headed to the tire deale... Sep 13 2017, 12:52 PM
GregAmy
This weekend, I'll be headed to the tire deal... Sep 18 2017, 08:36 AM
Robnxious
This weekend, I'll be headed to the tire dea... Sep 18 2017, 09:09 AM
Perry Kiehl My vote is 195/60's. Wouldn't it be nice ... Sep 13 2017, 08:37 PM
Larmo63 205/60 15s on deep sixes......
These fill the whe... Sep 13 2017, 11:05 PM
steuspeed Here is how the 195-55-15s look on a stock set-up.... Sep 14 2017, 02:38 PM
Robnxious
Here is how the 195-55-15s look on a stock set-up... Sep 14 2017, 03:54 PM
maf914 I've had 205/60 x 15 on my car for quite a whi... Sep 15 2017, 08:05 AM
Dave_Darling If you drop down to 50-series, there are still ver... Sep 15 2017, 11:19 AM
GregAmy
If you drop down to 50-series, there are still ve... Sep 15 2017, 11:29 AM
drifter914 I used to run the Eagle GT's in a 195/60x15 ... Sep 15 2017, 03:37 PM
Robnxious
I used to run the Eagle GT's in a 195/60x15 ... Sep 15 2017, 04:05 PM
euro911 I have Kumho tires on one of the 914s ... they gri... Sep 15 2017, 10:39 PM
Robnxious
I have Kumho tires on one of the 914s ... they gr... Sep 15 2017, 11:08 PM
euro911 Good all around tire ... I was quite impressed wit... Sep 16 2017, 12:02 AM
GregAmy Thanks! Yeah, I'm leaning toward 195/60-15... Sep 18 2017, 10:39 AM
Jamie I've been running Michelin Exalto 205/65x15 on... Sep 18 2017, 01:19 PM
horizontally-opposed Used to run 205/55R15s. Liked the width and perfor... Sep 18 2017, 03:09 PM
horizontally-opposed Used to run 205/55R15s. Liked the width and perfor... Sep 18 2017, 03:10 PM
ThreeV8s I picked up a set of Firestone Firehawk AS tires t... Oct 26 2017, 06:51 PM
GregAmy
I picked up a set of Firestone Firehawk AS tires ... Oct 27 2017, 08:30 AM
ThreeV8s
I picked up a set of Firestone Firehawk AS tires... Oct 27 2017, 08:51 AM
GregAmy So that was you...I was hoping it was someone on t... Oct 27 2017, 05:14 PM
ThreeV8s
So that was you...I was hoping it was someone on ... Oct 27 2017, 07:46 PM
euro911 Heck, at that a price, how could you go wrong? :u... Oct 26 2017, 07:09 PM
ThreeV8s
Heck, at that a price, how could you go wrong? :... Oct 27 2017, 04:24 AM
GeorgeRud 195/65-15 Michelin Exaltos on 6x15” Fuchs look r... Oct 26 2017, 08:42 PM
Cairo94507 George, your car looks terrific. :trophy: Oct 27 2017, 08:16 AM
ThreeV8s I had the Firehawks mounted today. From the ride ... Nov 21 2017, 08:24 PM
Mike1981 Hello
On my last car I ran
205-50-15 Potenza summe... Nov 22 2017, 01:55 PM
rhodyguy Pep boys had some great pricing on 185/65-15 all s... Nov 23 2017, 11:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 03:56 AM |
