| era vulgaris |
Aug 10 2016, 09:48 AM
J is for Genius ![]() ![]() ![]() Group: Members Posts: 986 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I've decided to put my 914 up for sale. I've had a lot of fun with it, but I've come to the conclusion that I really need a car that I can turn the key and drive, and that's not possible with carbs. Because of that I might consider a trade for a similar condition D-jet car, either 1.7 or 2.0 (see link to photobucket album at the bottom of the ad to view condition). I prefer the more oddball colors, I'm not so much into black, red, or white. Asking price otherwise is $15,900 OBO.
It was a lifelong California car until I brought it to North Carolina in December 2014. The previous owner I bought it from lived in Arroyo Grande, and prior to that it was owned by a married couple in Pasadena who were PCA members. This is an extremely solid 99% rust free car, the kind that you could only find in CA. The longitudinals, floors, and engine bay are as clean and solid as can be. The color is L50C Laguna Blue. I don't think it's original paint based on some small areas of overspray on the floorpan. But it is an older respray likely done 20 or so years ago; an estimation based on the fact that there are some chips, dings, and touch ups that would only come from many years of driving. I know the car photographs well but the paint is a 5 footer. Nevertheless you'll still have people giving you constant compliments on how good the car looks. The light blue against the black accents really looks good! Prior to my purchasing it, the previous owner spent a couple years from 2011 to 2013 doing a complete mechanical restoration which included many upgrades. The engine and trans were rebuilt by Mark DeBarnardi, who owns a very well known and respected shop called Original Customs, that specializes in air cooled Porsches. If you don't know of Mark or Original Customs, then to be honest you don't know 914's! Mark built the 2.0 case up to a 2270cc. Along with the rebuilt engine and trans, the car also received upgrades to the suspension, brake system, fuel system, shift linkage, and instrumentation which are all detailed below. ENGINE Rebuilt to 2270 Dellorto DRLA40 carbs (just rebuilt in March 2016) Mallory Unilite distributor MSD 6AL ignition module MSD Blaster II coil Tangerine Racing spiral wound spark plug wires Chromoly pushrods Swivel feet valve adjusters Deep sump tuna can Rebuilt 2.0 heads with 12mm spark plugs 78mm stroker counterweighted crank Galley plugs tapped and sealed Powdercoated engine tin and fan shroud Tangerine Racing oil pressure relief valve Tangerine Racing 1 5/8" headers Tangerine Racing EVO II exhaust Tangerine racing heat exchanger box Tangerine Racing remote oil cooler take-off kit External Setrab oil cooler with dual thermostatically activated 5" puller fans mounted under rear trunk Tangerine Racing braided stainless steel oil pressure sender hose All new seals and gaskets TRANSAXLE Rebuilt with stock gearing Tangerine Racing firewall shift bushing Tangerine Racing shift linkage New CV joints Tangerine Racing adjustable clutch pulley BRAKES AND SUSPENSION Brembo AM front calipers (rebuilt by PMB Performance) Stock 914 rear calipers (rebuilt by PMB Performance) New 19mm master cylinder Porterfield R4-S brake pads Braided stainless steel brake hoses 911 front suspension with 22mm torsion bars 911 vented rotors and hubs (front) Redrilled 914 rotors (rear) New front and rear wheel bearings Elephant Racing polybronze suspension bushings with grease zerks (front and rear) Tarrett 19mm adjustable front sway bar 911 struts (front) Rear adjustable coilovers with 220lb springs over Bilstien shocks Falken Azenis 205 50 15 tires on 15x7 Fuchs replica wheels FUEL SYSTEM Gas tank cleaned Tangerine Racing stainless steel fuel lines All new fuel hoses Tangerine Racing rotary fuel pump and fuel filter INTERIOR UPGRADES Aluminum pedal board Coco mats Center console with added instrumentation 4 channel digital Cylinder Head Temp gauge Digital Air Fuel Ratio gauge VDO oil temp and oil pressure gauges Repro hockey puck horn button MISCELLANEOUS New windshield New ignition switch Car was corner balanced New window scraper seals New door end cap seals New door handle seals New side targa seals New front trunk seal Center tunnel and pedal area treated with rust proofing paint Phenolic intake manifold gaskets There are about 18,000 miles that have been driven on the mechanical restoration detailed above. The chassis itself has about 140,000 miles on it. The car is broken in, and ready to be driven and enjoyed for many years to come. Recent compression test results done at the beginning of the summer are as follows on cylinders 1 thru 4: 140, 142, 144, 138. The only real issue I've had with the car is that the oil temp gauge is intermittent. Sometimes it works, but usually it doesn't. I've replaced the sender twice, and both times it would work for a couple weeks after and then slowly start not working again. I've traced through the wiring and can't find any faults. I'm really not sure what the issue is. But when the gauge does work, the temp is always right in the 200 to 220 degree range depending on how hard I'm driving. The thermostatically activated oil cooler and puller fans (which come on at 180 degrees) really do take all the worry out of your oil temps. I also have receipts for EVERYTHING listed above. Including the cost of the car, the previous owner spent approximately $28k building this car. With 914 prices on the rise, you wouldn't be able to replicate this car today without approaching $40k. The engine and trans build alone cost about $11k (carbs and exhaust not included, which would add another $4k to that cost). You could buy a decent driver 914 for just what the drivetrain in this car cost! I also have a stack of receipts and service invoices going back to the late 80's through the two previous owners that I mentioned earlier, back when the car was a stock 2.0. I also have a full set of 2 black keys, one red valet key, a spare blank black key, as well as an original leather PCA key pouch. And yes ALL of the locks work: doors, trunks, and glove box. I also have the original owner's manual, additional service manuals, California license plates, and a number of spare parts that will be included with the car. Most of the weather seals are in excellent condition. I replaced the ones that really needed it with the exception of the rear trunk seal, which could still do with being replaced. I don't drive the car in the rain, but the interior does stay dry when I wash it. All the seals are from 914 Rubber. The bumpers have been partially backdated to 916 fiberglass bumpers. It wouldn't be difficult to fully backdate them to stock metal bumpers if you wanted to. The mounting points and foglight conversion have already been taken care of. I did intend to do this when I first bought the car, but the 916 bumpers really grew on me (which honestly surprised me, but having lived with it I really like the look now). The fact that they match the body color makes the car look more like a modern car. And they're also much lighter which aids the performance of the car. Having driven stock 914's I can say this car really is what the 914 should have been to begin with. The upgrades put the HP somewhere around 130 or 140 HP. You really have no problem keeping up with and not just passing traffic, but putting it far far behind you. Not something you can say about a stock 1.7! And with the suspension upgrades you can take turns at absurd speeds. My favorite thing is when I get some macho muscle car guy behind me trying to ride my bumper. Then when we hit some twisties I'm suddenly half a mile ahead, and he's left wondering what happened! It's no problem to really drive the car hard, and your head temps will rarely get above 350 degrees. Typical cruising temps between 3k and 4k rpm are between 315 to 325 degrees, and even less if you're in slower speed limits that have you in 2nd or 3rd gear. Highway cruising in 5th at similar engine speeds will have you at 335 to 345 degrees. There's no worry ever of hitting, or really even getting anywhere near, 400 degrees. This, btw, was not the case when I bought the car. It was in a horrible state of tune and had a difficult time to not approach 400 degrees in normal driving conditions. I've put alot of work in to get the car to run as cool as it does! It's really absolutely worry free now, as far as head temps are concerned. As with most aircooled cars, it does leave a drop or two of oil behind after a drive. I recently had Black Forest Racing in Denver, NC replace the rear main seal back in early July of this year, but there is a still a drop or two that comes from that area. While I was there John Forbes, the owner of BFR, was eager to take the car on a test drive. He said he'd be happy to confirm the condition and performance of the car for anyone who wants to give him a call at the shop. Since then I've bought everything necessary to replace the RMS again and more (new Sabo RMS, new flywheel crush washer, new felt washer, new pilot bearing, new trans front seal, new schnorr washers for CV joints), and all of that will come with the car if I am not able to get around to doing the work myself before the car sells. (Don't worry Kevin, your clutch alignment tool isn't included in this!) I have a photobucket library with over 370 pics of every aspect of the car. Each album in the library focuses on a different area of the car. Link is here: Porsche 914 photobucket library If you have any questions, feel free to call or send an email. BTW, if you have a copy of this year's Fourteener Motoring calendar, you can see a small pic of this car on the inside of the back page along with all the cars that were in consideration to be in the calendar. Attached thumbnail(s) |
| dax1969 |
Oct 30 2017, 06:09 AM
Member ![]() ![]() Group: Members Posts: 400 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None
If this is the current market then I will never find one... pffft krgds Dax |
| era vulgaris |
Oct 30 2017, 07:00 AM
If this is the current market then I will never find one... pffft krgds Dax I think realistically it's maybe $17-$18k at best in this market if it's still in the same condition it was when it left my hands. I know this car, and anyone who would see it in person would immediately see that the paint and bodywork are what are holding this car back from being a $20k+ car. Give it a new paint job, smooth out the lumpy rolled rear fenders, and replace the torn seat bolster, and it might be worth $22k to the right person. |
era vulgaris Laguna Blue 914 2270 Aug 10 2016, 09:48 AM
era vulgaris more pics Aug 10 2016, 09:49 AM
era vulgaris more pics Aug 10 2016, 09:51 AM
era vulgaris more pics Aug 10 2016, 09:52 AM
era vulgaris As far as rust goes I've only found two very m... Aug 10 2016, 10:39 AM
era vulgaris Spot #2. That little black speck at the top of th... Aug 10 2016, 10:41 AM
MikeInMunich Awesome. Love it. No funds available. GLWTS. :)
... Aug 10 2016, 02:26 PM
2mAn Amazing car. PM sent Aug 10 2016, 03:40 PM
era vulgaris Bump for some videos!
Cold start...
https:/... Aug 22 2016, 03:12 PM
Chris H. I know commenting on FOR SALE threads is frowned u... Aug 23 2016, 09:33 AM
era vulgaris
I know commenting on FOR SALE threads is frowned ... Aug 23 2016, 11:37 AM
era vulgaris Here you go...20 min long extended drive through s... Aug 24 2016, 08:31 AM
era vulgaris ... Aug 26 2016, 09:15 AM
Evil914 Love that color! :Qarl: Aug 27 2016, 04:20 AM
era vulgaris Price drop to $16,900. Make an offer! ... Aug 27 2016, 09:49 AM
era vulgaris :bump:
Price drop to $15,900!!... Sep 2 2016, 02:39 PM
era vulgaris Sold! Sep 12 2016, 01:00 PM
iwanta914-6 Wow, someone is getting a great deal. Congrats on... Sep 12 2016, 02:44 PM
mepstein Congrats! Sep 12 2016, 03:17 PM
era vulgaris Thanks! :beer2:
The car's going back to... Sep 12 2016, 04:08 PM
Chris H. Nice. Great car. I still stare at the under-the-... Sep 13 2016, 07:19 AM
ww914 Congratulations on the sale of my "your... Sep 14 2016, 07:47 AM
era vulgaris Hey Warren!
Yeah I had a great time with it... Sep 14 2016, 09:52 AM
ww914
Hey Warren!
Yeah I had a great time with it... Sep 19 2016, 09:31 AM
era vulgaris Looks like the guy I sold it to is selling the car... Oct 29 2017, 03:49 PM
northwoodslakes@gmail.com
Looks like the guy I sold it to is selling the ca... Oct 29 2017, 06:23 PM
pete000 Flipper ! Oct 29 2017, 04:01 PM
JOEPROPER I thought that car looked familiar. Oct 29 2017, 07:36 PM
rosenfe So nice when a car for sale is presented with comp... Oct 30 2017, 05:43 PM
914_teener I was secretly pining for this car.
Glad it is co... Oct 30 2017, 09:31 PM
era vulgaris
Glad it is c... Nov 11 2017, 05:29 PM
Perry Kiehl I can't believe all the junk on FB about this.... Oct 31 2017, 06:05 AM
era vulgaris
I can't believe all the junk on FB about this... Nov 11 2017, 05:39 PM
Philip W. ad says it was always a Califonia car?? were you n... Nov 1 2017, 10:51 AM
era vulgaris
ad says it was always a Califonia car?? were you ... Nov 11 2017, 05:28 PM
thelogo Can i ask what you mean buy
A car you get in... Nov 2 2017, 09:59 PM
Perry Kiehl
A car you get i... Nov 3 2017, 08:26 AM
era vulgaris
A car you get i... Nov 11 2017, 05:32 PM
rhodyguy Did the sale include a clutch installation tool? ... Nov 4 2017, 07:30 AM
era vulgaris
Did the sale include a clutch installation tool?... Nov 11 2017, 05:26 PM
jipster43 That Facebook group is everything that's wrong... Nov 11 2017, 09:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:13 PM |
