PCV Valve, When to replace, where to get |
ThinAir |
Nov 3 2004, 10:06 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
How do you tell when your PCV valve needs replacement?
If you need one, where do you get it and about how much? I've checked Pelican and GPR, but can't find one. I haven't called Brad yet, but I know he can get anything. I'm just curious how much they cost. They aren't much for a Honda at my FLAPS, but I doubt they would have one for a 914. |
pbanders |
Nov 5 2004, 09:40 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
AFB = Anti-flashback. If I recall correctly, it's not a "valve", but a metal can filled with mesh that is connected through a hose on one side to the air box, and "tees" off on the other side to the heads. It's designed to stop backfire flame fronts from propagating to the heads, where the flame could ignite combustible gasses in the crankcase.
I just took a look in the factory workshop manual. Porsche also calls it a valve, but there is no valving mechanism inside of it that I'm aware of. The crankcase ventilation system functioning is described on the web page I referenced in an earlier posting. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:03 PM |
